20th Jun 2017, 4:37 pm | #1 |
Broadband transmission line transformer design ?
Photo from 'Practical Electronics for Inventors', which is a neat reference work of mine. It discusses a broadband transmission line transformer in the context of overcoming RF impedance-matching challenges.
I'm still focussed on this as I optimise my home AM rebroadcast set-up and try to improve VSWR into a short antenna. The base-loaded antenna design mooted in another thread by Argus25 is a great start, but I'd like to pop such a broadband transmission line transformer into an RF power stage. The concept is described: 'A broadband transmission line transformer is a simple device that consists of a few turn of miniature coax cable or twisted-pair cable wound about a ferrite core. Unlike conventional transformers, this device can readily handle high-frequency matching (it geometry eliminates capacitative and inductive resonance behaviour ). These devices can handle various impedance transformations and can do so with incredibly good broadband performance (less than 1dB loss from 0.1 to 500MHz.)' . P.270. Sherz.P, Monk, S. Practical Electromics for Inventors, McGraw Hill, Only the design isn't elaborated. My immediate application is for a centre frequency around 1.4MHz ... Any help in design concept and detail would be greatly appreciated. Thank you
Al |
20th Jun 2017, 4:55 pm | #2 |
Re: Broadband transmission line transformer design ?
The seminal article is C L Ruthroff "Some broadband transformers" Proc IERE August 1959.
Then Jerry Sevick wrote an awful lot (probably far too much) categorising baluns in vanishing detail. David
20th Jun 2017, 5:00 pm | #3 |
Just looking at your application (matching a short antenna into an AM rebroadcast set-up (pantry transmitter?), this actually looks like a comparatively narrow-band issue! Frequency range a fraction of an octave... or have I misunderstood?
20th Jun 2017, 5:42 pm | #4 |
It's possibly me who has understood. I am interested in the impedance-matching virtues that are underscored in the text I quoted. I assumed that from this description, such a broadband transformer has the capacity to match disparate impedances between any of the frequencies described. I didn't take it to mean that it does so only when there is a varying output signal between any of these frequencies...
Al |
20th Jun 2017, 7:55 pm | #5 |
I think the point is that such a transformer is good at matching impedances near those for which it was designed, over a wide range of frequencies. You perhaps have the opposite problem: a wide range of impedance (nowhere near a typical transmission line impedance) over a narrow range of frequencies. For your purpose a tuned matcher may be better. However, you have to be careful as too good a match could turn you into a broadcaster.
20th Jun 2017, 8:17 pm | #6 | |
Spot on, Dave. I've now got it exactly. Thank you for clearing it up. The thing is, it's hard to come across good designs for tuned matchers. I do want to keep my 2mH inductor base load and build from there. At the moment, it's the 2mH base load plus a short antenna (3m) terminated in a stainless steel ball with an estimated capacitance of 15 pF. I don't have a scientific way of evaluating VSWR but I suppose I could use a series bulb or similar for tuning? I don't enjoy working in a haphazard way. I have seen many variants of pi networks to deal with harmonics, but at the moment, these are not my focus, it's just the impedance match. Ahah, yes. Reasonable match is good enough for me, but I'm far from close to it at the moment.
Al |
20th Jun 2017, 8:21 pm | #7 |
Definitely a matching network job. Look up L or Pi to T match tuner. Only problem is you need to either know the antenna impedance or have an SWR meter as well. You can build the latter with little effort. There are some neat designs that use LEDs instead of meters etc as well.
Ignore Practical Electronics for Inventors for this sort of stuff. I really don't think it's a very good book if I'm honest. Experimental Methods in RF design by Wes Hayward has a section (3.6) on matching networks. If you can get hold of a copy of this it'll keep you up all night with the perpetual enlightenment on matters such as this. It's not impossible to obtain an electronic copy for review if you know where to look. |
20th Jun 2017, 9:03 pm | #8 | |
Ahah! I'll have a scout around, thank you! £100 for the hardback, I'll have to dig deeper on the internet!
Al |
20th Jun 2017, 10:39 pm | #9 |
Annoyingly RSGB shop used to stock it for £35 which is more reasonable but alas no longer.
20th Jun 2017, 11:52 pm | #10 |
Is there something about books I like and silly prices. Experimental methods in RF design is a really interesting read. £100.... wow! I also have a copy of C M Hargreaves The Philips Stirling Engine which was over £600 the last time one appeared up the Amazon. I must up my security. Uggrade the wolverines to rabid wolverines or something.
You design matching networks on Smith charts. I use LLSmith from www.rfdude.com Lance was a software guy made redundant who decided to take up RFery. I was one of the people who helped him a bit with his transition. David
21st Jun 2017, 1:22 am | #11 |
Experimental Methods in RF Design has just recently been re-released by the ARRL (American Radio Relay League) for $49.95.
An added benefit is that it comes with a CD containing electronic copies of two other very popular books of the time (1990's) Terry |
21st Jun 2017, 9:37 am | #12 |
Unfortunately if you order it from arrl.org, there's $30 on top of that for delivery that is tracked and then the poor exchange rate.
There are copies on a certain auction site and abebooks.co.uk at around £55 which is slightly less. |
21st Jun 2017, 10:27 am | #13 |
I wonder if a noise bridge would measure your antenna's impedance?:
https://www.youtube.com/watch?v=fiMbK8pjfNU Lawrence. |
21st Jun 2017, 12:31 pm | #14 | |
An SWR meter will be almost useless for measuring a small loop antenna. This is because an SWR meter is designed for use in a 50ohm system (or some system) and basically it measures how far off this standard you are - but doesn't tell you which direction (i.e. impedance) you are off. It gets less accurate the further away you are from a match. Your loop is nowhere near 50ohms so an SWR meter will simply tell you that it is a very bad match. Your best bet is to measure the inductance of the loop or calculate it. Then calculate the radiation resistance (proportional to loop area) and add the conductor resistance (calculate or measure) to get the total resistance. Then at a particular frequency you can calculate the series impedance. From that you can design a matcher. |
21st Jun 2017, 12:46 pm | #15 | |
Sprat number 61. "A dual directional power meter" It just sits there with 2 meters (or LED bargraphs or frog's legs or whatever indicators) One shows you the forwards power, one shows you how much gets reflected from the load. Much easier to visualise then VSWR. David
21st Jun 2017, 2:41 pm | #16 | |
This will only work at one frequency, or with a bit of luck a few. *measuring the resistance and reactance separately, and SWR meter only gives the vector sum. Complex as in leisure complex, not complicated. An SWR meter will tell you if you have got it right, not how to do it. |
21st Jun 2017, 3:37 pm | #17 |
Thank you folks! I'm out and about so will do short-form replies for now as using the quoting format takes ages to set up on iPhone!
MrBungle: thank you, that looks reasonable from AbeBooks David: thanks for that link, will investigate what looks like a very useful tool from your description. I will probably treat myself to Experimental Methods if I can get it for less than £50, or I might send a drone up to your place to borrow one, if that suits you? ;-) Sprat 61: ? Is your analyser idea a concept or does it exist in a replicable form? G8HQPDave: great points, thank you. Only I'm not necessarily committed to the loop; I'm now open minded about either loop or antenna. MM: thanks for your take on this, helpful insights there. Only I think I'll skip the. Vector Analyser. Saw a good one one EBay for just £130,000! I'm off to find an air-conditioned space. It's nudging 35 centigrade here and my brain is melting.
Al |
21st Jun 2017, 5:02 pm | #18 | |
21st Jun 2017, 5:07 pm | #19 |
How about Motorola AN267 'Matching Network designs with Computer Solutions' for a brief outline of common matching networks.
For designing networks on the computer my favourite is 'RFsim99' (freeware, available from http://www.microwavers.org/sw.htm. amongst other places. I run it on a virtual XP machine. There's a short video giving an idea of how it works on Youtube (in Spanish) https://www.youtube.com/watch?v=zcQyIby-K6Y (Filter design but it handles matching networks similarly.) Both date from the 90s but I still find them useful. Jim |
21st Jun 2017, 6:49 pm | #20 |
That's brilliant, thank you! PM sent!
Al |
