9th Aug 2013, 7:41 pm | #1 |
Toaster
I bought an old toaster in france which is the type that has a drop down door and toasts one side of bread at a time. The toaster has no make on it but has a drawing on how it should be wired for 120 or 240 volts. However when I wire it up the 240 volt way only 2 of the 4 heating slabs work, but when wired up the 120 volt way they all work. It then toasts one side of my bread in about 15 seconds.
The toaster has no earth cable by the way and gets very hot so is not double walled or whatever it is called, and is 600w. What I want to know is am I A. Putting my life in peril by using it. B. Putting the life of the toaster in peril. :mad: C.Likely to burn down the house. Why will it not work when I wire it for 240 volts ? Is it because the French system is different from the British system. Please help as my husband is seriously despairing and may chuck both me and the toaster out soon. |
9th Aug 2013, 8:10 pm | #2 |
Re: Toaster
I'm sure another forum member will answer your questions.
In the meantime stop using the toaster or you will destroy it. It would help if you could post a picture of the wiring diagram and a picture of how you've actually wired the toaster.
10th Aug 2013, 1:21 am | #3 |
Re: Toaster
If - and this is a big "if" - by that remark, you mean that there are only TWO wires in the mains lead that are connected to the mains plug, then I strongly suggest that you stop using it immediately and get it examined by a qualified and accredited electrician, because it sounds as though it is very dangerous to use - and could kill you or someone else.
Al. / Aug. 10, 2013 |
10th Aug 2013, 7:22 am | #4 |
Re: Toaster
It sounds as though there are 2 sets of heating elements which are wired in series for 240 V operation, or parallel for 120 V. If you can get them all to work on the 120 V setting, that means there are no breaks in the wire; but that way, you are actually giving them four times the power they are expecting (twice the voltage, times twice the current is four times the power) and this will cause damage in short order.
You will need to post some pictures of the terminals and the wiring instructions. In the meantime, as others have said, stop using it. Do you have, or can you borrow, a multimeter?
10th Aug 2013, 9:32 am | #5 |
Re: Toaster
Another important health consideration (if you don't already know) is that the heater elements could be wrapped around asbestos! If you're unsure, post some pictures.
http://www.youtube.com/ My Nixie Clocks |
