6th Sep 2008, 9:55 pm | #1 |
Transmitter number 21a circuit diagram
Hi
As you know this transmitter is on a circuit board - I am trying to get it into a number 28 telephone ( a very small space ) whose origional transmitter had disintigrated! . I have removed it from the red and the black casing and have removed the terminals, but it's still too big. It has 3 resistors, a capacitor and something else ( I don;t know what this is ) which has on it "Ferranti ZN 470AE 8222". I think that I might be able to fit these into the space if they wern't on the board. Does anyone know where I can find the circuit diagram for this transmitter - or does anyone have any other ideas? Are there any smaller transmitters? Thanks Regards Trev |
6th Sep 2008, 11:03 pm | #2 | |
Re: Transmitter number 21a circuit diagram
Regds, Russell W. B. G4YLI. |
9th Sep 2008, 10:02 pm | #3 |
Some years ago when I had nothing better to do, I disembowelled both a red mic insert and a blue mic insert: 21A DAE 82/1 and 21/A (AKG) repectively. You may find the attached drawings of use.
Knowing what the IC does isn't necessary, as long as you can remove all the components satisfactorily from the PCB and remount them where convenient. The IC (as I recall) is a standard 14-pin chip, so it should fit in a standard IC holder. HTH
13th Nov 2008, 1:10 pm | #4 |
Russell - hi,
Interesting info on the Type 21A DAE red Carbon-Compatible mic insert. I just assumed it was a true carbon mic and didn’t know it had an electret insert and Ferranti chip to emulate carbon. Do you, or any one else for that matter, know what the original specification for it was? Does any one know if there is a BT specification about still? What I am trying to find out is: - Its impedance at 1kHz, - Its output from speech (peak or average) when held normally in front of the mouth, and, - What voltage or current it needs to drive it. Thanks, Nick G8GRA/M0PYE |
13th Nov 2008, 2:24 pm | #5 | |
I have only done subjective testing of the mic and nothing amounting to science, but I shall say that the speech is crystal-clear compared with a 'Mic, Inset, No:13', although I think the spit-cup mouthpiece on the bakelite 164 (or equivalent) handset tailors the response slightly. Mine runs quite happily at 6V and draws 40mA - same as for the mic (Transmitter, Inset 13) it replaced. Now, the microphone capsule it was meant to replace is the 'Transmitter, Inset, No: 16'. I would consider the spec the same, as there don't seem to be any other mods to the telephones to which Inset 21A electrets were fitted. If there were, I'd expect those who know of them to speak up! I get the impression that the current / impedance spec hasn't changed from the original 'Transmitter, Inset, No:13', just performance and sensitivity have improved within the constraints of the original design. Do remember that 'Transmitter, Inset, No:13' (or inset No:10 - an earlier version) has been used on all instruments from the bakelite models of the 1930's and 40's through to the earlier type 706, and that they work equally well on a type 746 (or 8746), the instrument to which an electret type 21A was introduced in 1982. We found at work that telephones (this was when we had a BT 'Herald' analogue system) fitted with carbon mics were more prone to demodulation of RF from the high-power HF transmitters than those instruments fitted with a 21A capsule. If I find out more, I'll certainly let you know, but I have had no problems in the direct exchange of a type 21A for any earlier type of carbon insert.
13th Nov 2008, 3:49 pm | #6 | |
13th Nov 2008, 11:41 pm | #7 |
ZN470 see attached shortform.
Chris |
14th Nov 2008, 12:43 am | #8 |
Excellent! There was an AKG dynamic version as well, coloured blue.
