Old 23rd Jul 2018, 5:45 pm   #1
jomacot
Default Osram Music Magnet 4
Hi All,
I've been given a vintage radio by my son as a birthday present.
He says the guy that sold it to him insists it works.
Well maybe, but I have no information as to how to connect up the batteries, antenna and speaker because I do not have a diagram showing me what all the screw terminals are at the rear of the set.
Does anyone have access to anything approaching a user manual for this radio.
I've found a circuit diagram with a brief description in German but's more of a general guide to it's performance than a technical handbook.
Cheers all.
Jomacot.
jomacot is offline
Old 23rd Jul 2018, 6:19 pm   #2
dave walsh
Default Re: Osram Music Magnet 4
It's quite possible you will not have the skill set for this early receiver Jomacot.
You can access threads on here via "search this site" above eg "Osram 4 Music magnet by tigger" 10/7/12. These should give you an outline of what may be involved. Hope that helps.
Dave W
dave walsh is offline
Old 23rd Jul 2018, 6:22 pm   #3
ms660
ms660's Avatar
http://www.electrojumble.org/DATA/Mu..._4_with_AC.pdf
Lawrence.
ms660 is offline
Old 23rd Jul 2018, 7:32 pm   #4
Cobaltblue
Cobaltblue's Avatar
Just to add to Lawrences excellent link
https://www.radiomuseum.org/r/genera..._magnet_4.html
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 23rd Jul 2018, 7:40 pm   #5
AC/HL
AC/HL's Avatar
Back then there were no operating or service manuals. You got the build instructions on full size sheets, that's it. Radio was for the practical enthusiast, likely as not a member of a radio club.
There are two versions, the Music Magnet and the New Music Magnet, to make sure which one you have could you post a picture of the inside with the lid up.
Either way, you will need several batteries. A 2 volt accumulator, an HT battery and a grid bias battery. As Dave says, the search box above will be useful for research. No plug and play in the 20s unfortunately. Oh, and a long wire aerial, but that can come later.
AC/HL is offline
Old 23rd Jul 2018, 7:45 pm   #6
PJL
These are pretty simple sets. Can you post a picture of the bits you have and maybe we can help.
PJL is offline
Old 23rd Jul 2018, 8:38 pm   #7
Ed_Dinning
Hi you will also need a high impedance loudspeaker failing that you can use a low impedance speaker from a valve set, but with its matching transformer.
The basic kit set was just that, and you needed batteries, valves and a speaker and aerial to get it going.
I have some of these sets and they will operate well on local stations.
Ed
Ed_Dinning is online now
Old 23rd Jul 2018, 10:04 pm   #8
paulsherwin
paulsherwin's Avatar
I agree with #2. This will be a challenging radio for a beginner, and there's not a lot of stuff to listen to on the AM broadcast bands anyway. Maybe it would be better to treat it as a static exhibit?
paulsherwin is offline
Old 25th Jul 2018, 8:20 am   #9
jomacot
Thanks all for the excellent info. It may well be that it ends up as an ornament but initially I will try to get it working.
I have added two pics of the beast.
Incidentally, I have seen a rather battered one in an antique shop and it had a flat battery clipped to the right hand side, the pics show the clips on my one.
ID:	166538   Click image for larger version
jomacot is offline
Old 25th Jul 2018, 11:22 am   #10
AC/HL
AC/HL's Avatar
Definitely a New Music Magnet. The flat battery is the grid bias battery, inside because they last a long time as there is no drain from them. The 2 volt accumulator and large HT battery would be hidden away, possibly in another cabinet.
There are several threads on here (use the search box above) and quite a lot in other sites. If you pull off those aluminium cans there should be a valve under each one.
Do you have any test equipment, primarily a multimeter?
AC/HL is offline
Old 26th Jul 2018, 12:23 pm   #11
jomacot
Thanks, Yes I have both digital and analogue meters.
I downloaded the info from the link from ms660 which was great but still need to identify the screw terminals though so will study and see what I can deduce.
What voltage is the HT battery?
jomacot is offline
Old 26th Jul 2018, 3:13 pm   #12
AC/HL
AC/HL's Avatar
This is the construction sheet:
Name:	Music Magnet 1.jpg
ID:	166584   Click image for larger version
Name:	Music Magnet 2.jpg
ID:	166585   Click image for larger version
Name:	Music Magnet 3.jpg
ID:	166586   Click image for larger version
Name:	Music Magnet 4.jpg
ID:	166587   Click image for larger version
Name:	Music Magnet 5.jpg
AC/HL is offline
Old 26th Jul 2018, 3:16 pm   #13
AC/HL
AC/HL's Avatar
Continued:
If you PM your email address I'll send them without the size reduction if required.
Name:	Music Magnet 6.jpg
ID:	166590   Click image for larger version
Name:	Music Magnet 7.jpg
ID:	166591   Click image for larger version
Name:	Osram New Music Magnet 4.jpg
AC/HL is offline
Old 29th Jul 2018, 12:45 pm   #14
jomacot
AC/HL.
Sorry PM?
jomacot is offline
Old 29th Jul 2018, 2:48 pm   #15
Station X
Station X's Avatar
Private Message.
Click on AC/HL's username and select the appropriate option from the drop down menu.
Graham. Forum Moderator
Station X is online now
Old 29th Jul 2018, 8:16 pm   #16
AC/HL
AC/HL's Avatar
Thanks Graham, email now sent.
AC/HL is offline
