9th May 2012, 5:03 pm | #1 |
3 valve 1920s set
I have come across a complete 3 valve wireless with horn speaker. It looks to be in very good condition apart from a think layer of dust. It is built into a nice wood veneer cabinet with room for batteries below.
There is still an Ever Ready G.B.4 9v bias battery connected. I have some photographs and would like to identify the circuit so that I know what the rear connections are. The idea is to clean it up, test the components and then apply power. I have a nice 100v stabilised DC PSU for the HT and can use batteries for the heater and GB supplies. So, can anybody identify the set? Does anybody know of the circuit used? |
9th May 2012, 5:54 pm | #2 |
Re: 3 valve 1920s set
Hi Colin. The horn is a BTH C2. I have one of these and they sound really nice.
The set is TRF and might well be home made as many of these were. It will use a more or less bog standard uncomplicated circuit. I'm sure someone will correct me if it is a commercially made set but I don't think it is. HTH Ah!:- I have just looked and it is identical to the layout on my set but the cabinet is different. Before you do anything check the windings on that transformer for continuity. |
9th May 2012, 6:39 pm | #3 |
Also worth checking the grid leaks for value, they may well have turned into high class insulators! Bit of a job to see what goes where through the dust. As Dave has said, sketch out the circuit and you can probably see what is what. Looks like a regenerative detector followed by two stages of A.F.
9th May 2012, 7:11 pm | #4 |
HI Colin, when you have removed the dust see if there are any names on the large coil. That may give a clue as to its origins.
Ed |
9th May 2012, 7:53 pm | #5 |
A very nice set in 'original' condition, I wouldn't be surprised if it still works, there were lots of sets like that about when I was a kid but not many left, especially in that condition.
Peter |
9th May 2012, 7:57 pm | #6 |
The grid leak was indeed o/c on mine but you can open them up and pop a small modern resistor inside. Beware the markings tough (though). Mine were not the same as modern components. What I read as 3 Ohm was actually 3 MEGohm!
9th May 2012, 8:03 pm | #7 |
It's a 1927 Cossor Melody Maker, the first of a long line of radios.
They were sold as a kit, but the cabinet was made by various manufacturers. It was a three triode design, but a SG add-on unit was available. Later, a modification was released to convert the 1927 MM to screen grid. Yours is the original with the large tuning coil. PS Dust is always a good sign! Last edited by AC/HL; 9th May 2012 at 8:04 pm. Reason: PS |
10th May 2012, 12:53 am | #8 |
There was a convention where Ω (omega) represented megohms and ω (omicron) represented ohms.
Maybe that explains things.....
10th May 2012, 6:30 am | #9 | |
Colin |
10th May 2012, 9:34 am | #10 |
Actually, Ω is an upper-case Omega and ω is a lower-case omega (yes, the ancient Greeks had capital letters). The Greek letter Omicron (in both cases) looks the same as a Roman O.
10th May 2012, 9:11 pm | #11 |
There never was a circuit as we know it today.
You used a full size drawing to lay out the parts on the baseboard and Ebonite front panel. The drawing also had full size impressions of the wiring, which were cut, bent and sleeved beforehand. Then it was simply connected up and away you went. The attachments are sections of the instructions that were kindly supplied to me by a forum member some time ago. They aren't complete, but I think they have all the information you need to get it going. |
11th May 2012, 2:55 pm | #12 | |
Well I only managed a 9 in Greek O level......
15th May 2012, 5:37 pm | #13 |
Thanks the diagrams certainly helped. I did some checks today and the secondary of the transformer is open circuit. It's a Ferranti AF3. What are the chances of getting a replacement?
Colin |
17th Apr 2015, 10:58 am | #14 |
Location: Sycamore House, Shankill, Dublin D18, Ireland
Hi Colin,
Did you end up finishing this set restoration? That transformer could be rewound although it's probably got thousands of turns of fine wire. I found an article in Practical Wireless May 1980 where Robert Thorton reported getting reasonable results using a small 20-0-20 V mains transformer as an intervalve transformer giving a step-up ratio of about 1:6. This is what I'm trying out in a TRF (you can see the thread so far on https://www.vintage-radio.net/forum/...php?p=745268)- I'm always hoping to finish making the parts!
This retirement thing is worse than it was cracked up to be! |
