1st Apr 2010, 8:30 pm | #1 |
Correct wiring fo 700 series Handset
Hi everyone could somebody provide me with the correct wiring colors for 700 series handsets i have done many but recently have had a few in that are wired the complete opposite the the way i normally do it. Now i am wondering have i done them correctly in the past. I normally do the earpiece looking at it with the terminals at the bottom red to the left terminal and green to the right.
I do the microphone looking at it with the terminals at the top white to the left and blue to the right is this correct or doesn't it make a difference. Opinions as always much appreciated. Rich |
1st Apr 2010, 9:02 pm | #2 |
Re: Correct wiring fo 700 series Handset
It does not matter which way you connect the wires. Red and green to receiver. White and blue to the transmitter/mic.
1st Apr 2010, 9:04 pm | #3 |
Doesn't make a ha'porth of difference. Red / green to receiver (there should only be AC on it anyway); blue / white to mic. It's just a carbon-filled variable resistor after all, and the type 21 electret insert has a bridge rectifier across the input so polarity isn't important.
Regds, Russell W. B. G4YLI. |
1st Apr 2010, 9:13 pm | #4 |
Guys as always thanks for info. Its pretty much what i thought but i do have a bad habit of second guessing myself. I very much appreciate everyone that takes the time to help and advise, you all make my hobby the enjoyable pass time it should be.
Best Regards Rich |
