1st Aug 2010, 2:05 pm | #1 |
220pf Cap
I'm gathering the bits I need to recap a Philco 3650 and I need a 220pf cap, Polypropylene axials are recommended on here but I'm struggling to find this value, will they be listed as as diferent value? Also, I need a couple of .05uf caps, are these available or will I need to substitute with a different value?
I'm new to this as you might have guessed. Thanks, Mark. |
1st Aug 2010, 2:27 pm | #2 |
Re: 220pf Cap
220pf
http://uk.farnell.com/lcr-components...30v/dp/9520716 And use 0.047 for the 0.05, the old caps where likely 20% tolerance, it won't matter. |
1st Aug 2010, 2:28 pm | #3 |
Re: 220pf Cap
Forgot, Farnell do sell to individuals vis credit cards etc. £20 minimum order so get a bunch of 0.1s too.
1st Aug 2010, 2:43 pm | #4 |
Re: 220pf Cap
or here for 220pF
http://www2.cricklewoodelectronics.c...cat=154&page=1 (The Farnell one is polystyrene not polypropylene, not sure if the difference is critical!) Michael |
1st Aug 2010, 2:44 pm | #5 |
Re: 220pf Cap
Thanks very much.
1st Aug 2010, 4:25 pm | #6 |
Re: 220pf Cap
Polystyrene and polypropylene are equivalent in electrical properties.
John |
1st Aug 2010, 8:57 pm | #7 |
Re: 220pf Cap
Just Radios do caps in tube radio values.
www.justradios.com |
1st Aug 2010, 10:19 pm | #8 |
Re: 220pf Cap
If you want polystyrene, I'll send FOC if you PM me.
Roy |
2nd Aug 2010, 8:40 am | #9 |
Re: 220pf Cap
PM on its way, Roy.
2nd Aug 2010, 8:47 pm | #10 |
Re: 220pf Cap
2nd Aug 2010, 9:22 pm | #11 |
Re: 220pf Cap
Please ignore my last post -missed FOC one
