#21 | |
![]() Quote:
Jim. |
#22 | |
![]() Quote:
![]() ![]() Frank N. |
#23 |
I don't see that powering this device is the main problem.
Mains transformers are not usually so tight that you can't pinch an extra 100mA of heater current. In most cases you could fit a small mains transformer somewhere in the cabinet that would deliver 1 amp at 5V which should be more than enough. It would be far neater to have it as a plug-in replacement for the original though. Something that might be a nuisance is the RFI from the clock. Pete. Last edited by XTC; 25th Mar 2006 at 3:18 pm. |
#24 | |
Well, since the cat is already out of the bag I might as well post the rest of my ideas for making an EM34 substitute.
What I have in mind is:
But I plan to take this one a step at a time. First a breadboarded prototype as proof of concept. Then, depending on how convincing the results are, I may build a 'genuine' replacement in the EM34 form factor. I have been looking for an excuse to play around a bit with today's embedded controllers, and this application looks perfect. Anyone having a dead Octal valve with the small diameter base they want to part with, please? ![]() Frank N. Last edited by YC-156; 25th Mar 2006 at 4:45 pm. |
#25 | |
![]() Quote:
I have a dead VT52 which appears to be about 28mm diameter of outer and 20mm across the pins. One complication - it has no pin 6. May be possible to extract pin 1* (N/C on EM34) and relocate it. *perhaps it needs the services of our resident dentist ![]() edit: I've just noticed that there are two types of VT52 - mine is the one with the octal base (labelled VT52(RAF) in TDSL. |
#26 | ||
![]() Quote:
![]() So if it is surplus to your requirements...? ![]() Best regards Frank N. |
#27 | |
![]() Quote:
#28 |
A further thought -
RS stock "electroluminescent film" in various colours. It looks as though one supplies it with 20 / 200 volts and it glows in a fairly satisfactory manner. I haven't played with it but I'll add some to my next order and report back. Regards,
Brian |
#29 | |
![]() Quote:
![]() I will wait until I hear from you before shipping it. |
#30 |
Never mind...
A friend just came by and dropped off (not literally) the recently acquired set for which I was sure I would need this gizmo. Something worthy of an extra effort I would like to believe. Did I ask the seller if he would package it carefully? Did I offer to pay (quite a bit) for 'extra care in packaging'? Did he tell me that this certainly wouldn't be needed? Did he stuff the poor thing (all 18kg of it) in a thin cardboard box about 2cm larger than the set in all directions and stuff it with curled up newspaper so hard that you had a near 1:1 transmission of forces from the box to the sides of the radio? Did this predictably break the (probably irreplaceable) dial glass into four pieces? ![]() ![]() ![]() ![]() |
#31 |
Deepest condolences.
Posting vintage equipment is such a lottery unless the person posting is a fellow enthusiast – but sometimes it’s a gamble that is difficult to avoid.
Chris |
#32 |
Thanks Chris,
Well, hope I don't drift too far off topic here, but after closer examination I'm not sure this cannot be mended. While there are actually five main pieces plus all the tiny shards, it just might be possible to glue this back together, followed by a touchup to the paintwork on the back. Due to the location of the cracks it might not be that visible, once everything is back together. I happen to know a genuine glass craftsman, but I suspect he will rob me blind for fixing this puzzle. But I'm afraid my EM34S(emiconductor) project is on hold for now. Brian, It would be quite interesting if they can be cut up into smaller pieces. If so, then they might be an interesting alternative to LEDs. Jeffrey, My reason for choosing a PLCC was that I would like others to be able to copy the project if they wish. To that end I prefer only to use SMDs as a last resort, and a PLCC plus socket will fit, if only barely. The caps I probably need are something on the order of 1000uF/16V and ripple is not the issue here, supply current is. ![]() Best regards Frank N. |
#33 |
Administrator
Please bring this back on topic, or it'll be closed. Thanks!
Paul Stenning Forum Admin/Owner and BVWS Committee Member |
#34 | |
![]() Quote:
Regards,
Brian |
#35 |
EL film is interesting.
I assume the Konica ad at the foot of this page is made of it and it looks a bit like a magic eye. http://world-electroluminescent.com/EL_light.html Pete. |
