Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets and Parts Wanted (private buyers only, no swaps)
Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 22nd Jun 2024, 4:54 pm   #1
DonaldStott
DonaldStott's Avatar
Default IFT Screening Can
I'm missing the screening can for the 1st FM IFT on the radio I'm currently restoring - Murphy A272C. These seem to be of a standard size (?) so I'm hoping someone out there has something suitable. The other IFTs appear to have a 'celluloid type' internal sleeve as well.
ID:	299423 Click image for larger version
ID:	299425 Click image for larger version
PM me please if you have a spare screening can of this type and size - happy to pay costs and p&p.
BVWS Member
DonaldStott is offline
Old 23rd Jun 2024, 6:41 am   #2
Gabe001
Default Re: IFT Screening Can
Have you seen this thread
https://www.vintage-radio.net/forum/...d.php?t=212010
Gabriel
Gabe001 is offline
Old 23rd Jun 2024, 9:13 am   #3
DonaldStott
Originally Posted by Gabe001 View Post
Thanks Gabriel
BVWS Member
Old 23rd Jun 2024, 9:16 am   #4
Leon Crampin
Are you sure there's one missing? On this chassis, the AM aerial coils assembly has no can by design, whereas the first FM IF coil assembly does. These cans frequently get swapped over, for some reason.
Leon
Leon Crampin is offline
Old 23rd Jun 2024, 11:09 am   #5
DonaldStott
Leon
Thanks Leon, understood - I just assumed that as the AM aerial coils assembly and the 1st FM IFT had the same bases then a screening can was missing: -
BVWS Member
Old 23rd Jun 2024, 2:56 pm   #6
Julesomega
Julesomega's Avatar
My parents bought a 272C new in ca. 1956, I'm sure it was 'installed' by the retailer's engineer, who whipped the back off, removed the aerial can, and explained that it avoided needing an external aerial. I've remained impressed at the sensitivity of the set, as it then had a ferrite rod in the form of about an inch of ΒΌ" ferrite inside the coils, and would receive the near continentals all day on LW, and didn't really benefit from an external aerial.
- Julian
It's good here
Julesomega is offline
Old 24th Jun 2024, 8:13 am   #7
Leon Crampin
Check the Murphy A272C service data before speculating about can removal. On this chassis, the FM aerial also serves as an AM aerial in a balanced input arrangement.
Leon.
Old 25th Jun 2024, 12:17 am   #8
Julesomega
Julesomega's Avatar
That sounds like a better reason for the good AM reception without an external wire aerial.
- Julian
It's good here
Old 25th Jun 2024, 7:46 am   #9
dazzlevision
Here's a photo of the chassis in an A272C and an A272.
ID:	299508   Click image for larger version
Name:	Murphy A272 chassis full view.jpg
dazzlevision is offline
Old 25th Jun 2024, 5:04 pm   #10
DonaldStott
And here is a photo, slightly blurred, of the A272C chassis from the Radiomuseum site: -
BVWS Member
Old 26th Jun 2024, 11:41 am   #11
DonaldStott
I am of course taking the advice of Forum members that '... the AM aerial coils assembly has no can by design...' (Leon Crampin) but of course I'd like to know why as the coils seem very exposed to me - see picture in my Post #5 above?
BVWS Member
Old 1st Jul 2024, 11:32 am   #12
Julesomega
Julesomega's Avatar
The Radiomuseum photo seems to confirm my recollection, and my guess is that this model was usually delivered without the RF can because its removal would necessitate re-aligning, which the engineers would usually have already done in the workshop.
Coincidentally, I've just unearthed one of those electrolytics with the top-up bungs, saves me having to ask what they would have been used in.
- Julian
It's good here
Old 1st Jul 2024, 4:54 pm   #13
Leon Crampin
Page 6 of the Murphy service manual for the A272C gives a line drawing of the upper chassis view. The AM aerial coil is shown just as a crosshatched circular bare coil, wheras the FM IF coils assemblies are drawn with a circle around them - denoting a can.
Leon.
Old 2nd Jul 2024, 12:54 am   #14
Julesomega
Julesomega's Avatar
Really? In that case, I withdraw my, um, case. it's too long ago to remember properly and was long before I developed a technical interest in Radio. The Radiomuseum guy may have borrowed a can for his restoration, assuming it was missing.
I wonder if it would be possible to tune the LF end correctly with a can on?
- Julian
It's good here
Old 2nd Jul 2024, 9:50 am   #15
DonaldStott
Leon.
Thanks for that - understood.
Indeed Page 3 of the Trader Service Sheet 1413 for the Murphy A272 makes it very obvious!
BVWS Member
Old 2nd Jul 2024, 9:55 am   #16
Cobaltblue
Cobaltblue's Avatar
As this can is no longer required I will close this wanted thread.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Copyright ©2002 - 2024, Paul Stenning.
