14th Feb 2020, 11:32 pm | #1 |
9TAHC cartridge query
I am trying to wire up a 9ta hc cartridge to a bush that has red,blue, yellow and black wires, can someone tell me which wires go where? also must they be soldered or should they plug in? all advice welcome |
15th Feb 2020, 1:50 am | #2 |
Re: 9TAHC cartridge query
As far as I can remember there was a round nylon plug which pushed into the rear of the cartridge, red and black one channel, blue yellow the other. Could be wrong, long time ago!!!
15th Feb 2020, 2:39 am | #3 |
Hopefully the attached images will help. The usual colour code convention is:
Red - Right Signal Green - Right Ground White - Left Signal Blue - Left Ground Probably best to trace your wiring back to the input of the amplifier to be absolutely sure of the correct connections although buzz testing might help. The small plug should be removed from the main body before carefully soldering the wires to the appropriate tabs. Alan |
