28th Aug 2013, 11:57 am | #1 |
Toko rf catalogue (cirkit)
Cirkit were selling a Toko RF Catalogue in 1994 which contained more information on Toko coils than was in the Cirkit catalogue itself. Does anyone have a copy of this please? I need some info on a Toko coil's applications which isn't in the straight Cirkit catalogue.
3rd Sep 2013, 11:19 pm | #2 |
Re: Toko rf catalogue (cirkit)
Hi Jim, I have a Toko catalogue from about 1991 which may contain the info you are after. I also have the Toko filter catalogue which covers ceramic types from that era. If you need info on a particular component I could send you a copy.
Alan. |
3rd Sep 2013, 11:21 pm | #3 |
I have some ambit catalogues not complete. What coil do you need info on.
regards Pierce ei7ka |
4th Sep 2013, 6:03 pm | #4 |
Cheers Guys: It's the WFDC1115P/S.
Many thanks, I'll PM you my email address, Jim |
4th Sep 2013, 7:19 pm | #5 |
Jim, I've had a look through both catalogues and there's nothing close to that number. What type of component is it? Sometimes you can find the numbers "hidden" among longer ones in my experience, with odd prefixes etc.
Alan. |
5th Sep 2013, 9:12 am | #6 |
It's an AM 465kHz double tuned IFT (see diagrams). It can be configured using mutual inductive and/or link coupling but I have no information on how to do this,
Jim |
5th Sep 2013, 8:20 pm | #7 |
Hi Jim, I've had a look through the books again and there is no mention of that coil except in the Cirkit catalogue itself which is the same as the info you already have. There is maybe another more comprehensive catalogue available as the one I have doesn't seem to have any circuit suggestions in it. Sorry I can't be of any more help. It's a shame that most of those useful RF components and kits in the Cirkit catalogue are no longer available.
Alan. |
6th Sep 2013, 12:15 pm | #8 |
Cirkit also advertised the Toko RF Catalogue at that time which they must have produced themselves as the illustration shows it bearing the Cirkit logo. It's that I'm trying to find a copy of as it contains "much technical information" but nobody seems to have it (including Toko themselves!!!!). Many thanks for your efforts,
Jim |
6th Sep 2013, 6:50 pm | #9 |
Hi Jim, that certainly sounds like the book I have as it has the Cirkit logo on but mine's dated 1991. I wonder if there's another version. I think I got mine through a third party company when I was in a different job in the nineties. From the pinout it looks like two separate units which have to be intercoupled. It's a bit like an NBFM detector set up, maybe with a quadrature coil in there as well.
Alan. |
6th Sep 2013, 10:38 pm | #10 |
There is. My Cirkit catalogue is from Summer 1994 and the Toko catalogue they are offering (for £2.50) is the 2nd edition.
Jim |
7th Sep 2013, 12:48 am | #11 |
Ah..That explains it! They are very useful reference books if you tinker with home built stuff. Never throw a catalogue out, that's what I say. I wonder how many of the kits are still around half built and forgotten about.
10th Sep 2013, 1:06 pm | #12 |
I thought I had sussed out the connections but Pierce has just sent me the required diagram and I was completely wrong! Many thanks Pierce!
27th Dec 2013, 11:20 am | #13 |
Hi.
Does any one know of an equivalent or data for what Ii believe to be a Cirkit No.35-01842 coil used on an MC3359. 23cm txrx, Elektor (Sept 1992) by Tim Forrester G4WIM? |
27th Dec 2013, 11:25 pm | #14 |
Hi Stefang,
It's a TOKO 5SL0184R 5mm coil. This is a 455kHz AM 3rd.IF coil which is a smaller version of the commoner 10EZ coil, type YHCS11100. I don't have any of the 5mm coils but can let you have one of the others if you want to use it. You'll have to increase the spacing of the PCB pads to use it but this should be possible to do. Jim |
27th Dec 2013, 11:26 pm | #15 |
I'll check my catalogue and see if there is any info on it. What frequency is the IF running at as that will give you a clue to the type of coil it is. Usually the only coil required with an MC3359 is the quadrature coil in the FM demod circuit, tuned to the IF frequency.
Alan. |
28th Dec 2013, 12:15 am | #16 |
I've had a look and found the coil data. It's a type 5SL0184R (equivalent but smaller version of the YHCS11100) which is a 455KHz IFT Q=77, turns between pins 1-2=137, between pins 2-3=43, between pins 1-3=180, between 4-6 (secondary) 27. Usually only the tuned primary is used with the MC3359 so it may be possible to use a 455KHz IFT from an old transistor radio and connect the tuned primary into circuit using the outer pins of the coil, ignoring the primary tap. 1-2-3 are the primary, 4-6 are the secondary connections. 1-3 are the outer connections to the primary, 2 being the tap. Hope this helps.
Alan. You just beat me to it Jim! Last edited by Biggles; 28th Dec 2013 at 12:16 am. Reason: duplicate info |
28th Dec 2013, 1:29 pm | #17 |
Quick draw they call me Biggles!
I've got lots of 455kHz IFTs kicking about if only the primary is needed Stefang. Jim PS: why "Biggles", Biggles? Are you into aviation too? (I learned to fly- gliders- at RAF Ouston, not too far from you back in 1959). |
28th Dec 2013, 4:10 pm | #18 |
Hi, Many thanks for the quick replies i am looking for 2 off these coils but i don't know any one who stocks them? the boards i have are pth and very tight on space, I am also looking for an equivalent for an ATF13484 gasfet? this may not be vintage but it dates back to 1992.
I am also looking for conduction cooled 4cx250's and 9 pin bases for pl504's if any one has any? Many thanks Stefan G7SPG I learned to fly in Piper Tri-Pacers and Chipmonk's |
28th Dec 2013, 11:30 pm | #19 |
Stefang,
Try contacting jabdog@blueyonder.co.uk. he might be able to help. I'll see what 5mm coils I have , if any, tomorrow. Jim |
29th Dec 2013, 1:39 am | #20 |
It may be worth looking inside an old cordless phone handset, the type that were in use before DECT ones came out. These sometimes have similar chips and quadrature coils in the receiver which can be removed with a bit of care. Most of the ones I have cannibalised use the 5mm coils inside to save space. (I'll check out that forum link Jim.)
Alan. |
