Old 8th Oct 2019, 10:14 am   #1
Blue Suede Ted
Default Elizabethan tape recorder model 56
Can anyone identify this Elizabethan tape recorder please?
The valves it uses are:- EF86, ECC83, EL84, and 6X4 rectifier.
ID:	191511   Click image for larger version
ID:	191512   Click image for larger version
ID:	191513   Click image for larger version
Blue Suede Ted is offline   Reply With Quote
Old 8th Oct 2019, 11:06 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Elizabethan tape recorder. ID?
I can't see it on Radiomusem: https://www.radiomuseum.org/m/eap-e_gb_en_1~year.html
Presumably it's one of their earliest products. The fact that the model name is simply "Elizabethan" also points to this, I suppose.
OTOH, does it say "May 1960" on one of those big caps?
Good luck with it.
Old 8th Oct 2019, 11:08 am   #3
Nickthedentist
Dave has something about the company here: https://www.vintage-radio.net/forum/...87&postcount=8
Old 8th Oct 2019, 1:13 pm   #4
af024
Is this the Elizabethan 56?
Now where on earth did I remove that from?
af024 is offline   Reply With Quote
Old 8th Oct 2019, 1:17 pm   #5
Neutrino
This has 2 clasps for the lid instead of a lock:
ELIZABETHAN 56
52 gns.
Tape Recording and Reproduction Magazine Sept 1957 Page 25
https://www.americanradiohistory.com...UK-1957-09.pdf
54 gns in March 1958 and the Essex is 75 gns:
https://www.americanradiohistory.com...UK-1958-03.pdf
Perhaps superseded by the new Elizabethan ESCORT which is advertised at only 45 gns in June 1958 page 5:
https://www.americanradiohistory.com...UK-1958-06.pdf
"A sound idea!" if you scroll down this:
https://thevintagetoyadvertiser.org/...appy-new-year/
Not identical but a lower price of 48 gns.
Neutrino is offline   Reply With Quote
Old 8th Oct 2019, 1:54 pm   #6
Nickthedentist
Good work, af024 and David!
Pic from the first link David's posted below...
Old 8th Oct 2019, 2:13 pm   #7
Edward Huggins
This looks to be in complete contrast to the far more value-engineered Elizabethan products of the early 1960s based around the BSR TD2 and Motek 3 speed decks.
Mind you they did the job well and sold in quite large volumes. And probably contributed to the demise of those Walter machines....
Edward.
Edward Huggins is offline   Reply With Quote
Old 8th Oct 2019, 2:29 pm   #8
Techman
Techman's Avatar
It uses Collaro motors and almost looks home made.
In the above posted advert you can see that they actually use a complete Collaro deck in the 'de-luxe' model.
They must have had a deal with Collaro at the time to be able to use the motors in that in-house deck, unless, of course, the deck is actually made by Collaro for them. However, I seem to think that I've come across Collaro motors like that in other unusual in-house tape decks.
Techman is offline   Reply With Quote
Old 8th Oct 2019, 2:43 pm   #9
Hartley118
Hartley118's Avatar
That looks like a Motek K10 deck. Decent performance with excitingly fast wind speed!
Martin
BVWS Member
Hartley118 is offline   Reply With Quote
Old 8th Oct 2019, 2:52 pm   #10
Techman
Techman's Avatar
And fitted with three Collaro motors!
Old 8th Oct 2019, 3:22 pm   #11
Blue Suede Ted
Electrolytic C’s are dated May 56.
It certainly looks like model 56.
I’ll see if there is a manual available.
Thanks for all the help.
Peter
Old 8th Oct 2019, 3:34 pm   #12
wd40addict
wd40addict's Avatar
Collaro were happy to sell motors on the open market, Scophany-Baird were one such customer, Motek look like they were another.
It could even been motor sales into the emerging tape deck market that persuaded Collaro to have a go themselves leading to the transcriptor.
wd40addict is offline   Reply With Quote
Old 8th Oct 2019, 3:40 pm   #13
Blue Suede Ted
Can’t locate a Elizabethan 56 service manual!
Has anybody got one I could buy or copy, or know where to get one?
Thanks
Peter
Old 8th Oct 2019, 5:55 pm   #14
Restoration73
Restoration73's Avatar
If you send a PM I can scan the circuit and data from the Hellyer book and email it to you
Restoration73 is offline   Reply With Quote
Old 8th Oct 2019, 5:57 pm   #15
Heatercathodeshort
Heatercathodeshort's Avatar
I have one of these recorders hidden away. I must locate it and post some pics. I thought it was badged FIDELITY but I may be wrong. John.
Old 8th Oct 2019, 7:34 pm   #16
Restoration73
This circuit is the 56
Old 9th Oct 2019, 11:47 am   #17
Blue Suede Ted
Printed off cut. Thanks for all your help
Peter.
Old 9th Oct 2019, 5:59 pm   #18
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
You neglected to mention the magic-eye.
Colin.
ColinTheAmpMan1 is online now   Reply With Quote
Old 17th Oct 2019, 12:25 pm   #19
Blue Suede Ted
Has anyone got a diagram of the motor and control wiring of Elizabethan 56 tape recorder, or know where I can get one?
Thanks
Peter
