26th Apr 2020, 1:12 pm | #1 |
Can anyone identify this radio (Stromberg Carlson Maestro 4A20)
I have searched the radio museum by valve numbers and nothing matches this radio.
Its a 4 Tube set with a 4" Rola speaker. There is a metal plate front end with the dial glass on a 45 degree angle to the top. Looking from the front, both control knobs are side mounted. On/Off/Volume on the Left and Tuning on the Right Tube Numbers: ECH33, 6ARTGT, EL33B and a 4th tube that only says Radiotron made in Australia. The seller told me its a Stromberg Carlson but I can find no matching pictures on the net or radio museum so I tried doing the Tube numbers search. Every radio with an ECH33 & 6AR7GT is a 6 Tube radio and this unit seems not to exist. Bought as a chassis only so would like to see if there is a case for this radio somewhere in the world. No markings on the chassis either but the design looks universal so they could mount the controls at the front for a different body case See photos for more details. 5th picture is the Radiotron tube I think it is a rectifier but markings have worn off.
If only he could have used his evil genius for niceness instead of evil. Max Smart 18 Sept 1965 |
26th Apr 2020, 1:23 pm | #2 |
Re: Can anyone identify this radio
The valve lineup sounds very Australian and the tuning scale is certainly Aussie. Australian radio design was surprisingly idiosyncratic for a country with a relatively small population at the time, with makers using an odd mixture of American, European and British practices, combined with some home grown ones too.
SC did have an Australian operation. |
26th Apr 2020, 1:28 pm | #3 |
All the other 3 tubes are Philips Miniwatt and at least 1 of them say Australia on there.
But as for any other identification marks on the radio, there just isnt any.
26th Apr 2020, 1:34 pm | #4 |
Philips did sell their Miniwatt brand in Australia, and they may have manufactured valves there too. A 6AR7 would not be a valid Philips designation in Europe at that time (it's a 1935 American design).
Aussie members may have more info. Australian made valve radios are a rarity here in the UK, so knowledge is limited. |
26th Apr 2020, 1:37 pm | #5 |
Definately a Stromberg Carlson, since it is printed on the painted panel behind the tuning scale, as can clearly be seen in the third photo. Might be worth looking behind the tuning scale for the model,if not already done so. A rather rare set to my mind, not even heard of the manufacturer. Good look finding info for it.
26th Apr 2020, 1:40 pm | #6 |
SC were a major American manufacturer, but didn't operate in the UK or Europe.
26th Apr 2020, 1:40 pm | #7 |
Thanks Paul,
It doesnt seem to match any of the Stromberg Carlson or Philips radios on radio meuseum. Any idea what that 4th Valve is. I mean I am guessing its a rectifier but I am still fairly inexperienced at this. Perhaps if I had all 4 tube names I would have more luck tracking it down. I might do a quick flick through Youtube to see any radio restos with side mount controls. Both sides have extensions on them too that must need to be removed to get the chasis out of a bakelite case. Total guess though. Neil
26th Apr 2020, 1:43 pm | #8 | |
I completely missed that with my glasses on and a magnifying glass. Thanks Dave I will do some more investigations
26th Apr 2020, 1:44 pm | #9 |
The 4th valve is almost certainly a rectifier. The radio appears to be a 'short superhet' with only 3 amplifying valves instead of the more common 4. Short superhets were quite common in Oz.
26th Apr 2020, 2:09 pm | #10 |
SOLVED
Its a 1950 Stromberg Carlson Maestro 4A20 Knobs are side mounted in the pics and dial glass is a match. Looks like they used quite a variation of tubes in its production which probably fouled the search engine up. https://www.radiomuseum.org/r/stromberg_4a20.html If I cant find a case for this radio I may just build a wooden cabinet for it.
26th Apr 2020, 2:33 pm | #11 |
The ECH33 and EL33 could be service replacements. They are near equivalents of the types listed on Radiomuseum.
26th Apr 2020, 2:58 pm | #12 |
Cant seem to find a diagram on radio museum for the radio.
They say it is on page 300 of Australian Official Radio Service Manual AORSM Vol 9 1950/51. Guess I am going to be scouring through old book shops for a whike to find a copy. Or wait till our state library is open again as it seems they have a copy
26th Apr 2020, 3:04 pm | #13 |
There are only a small number of standard AM radio designs. Anything with a 6AR7 inside is likely to be a short superhet with the 6AR7 providing the IF amplifier and detector/AGC diodes. (Most similar UK designs put the diodes inside the output pentode by using an EBL31). If you search for a circuit using a 6AR7 then it will be very close to this radio.
26th Apr 2020, 3:29 pm | #14 |
Thanks Paul.
I did wonder if that would be the case. This would mean I should be able to find my way through the set using either the Air Hostess 4A19 or 4A19-A Diagrams. Will just have to study the differences in any of the tubes so I dont mess up if there is variances in the pin outs. Most of the components on my chassis are in good shape and still have their markings which makes life a bit easier in that respect. Thanks again. Neil
26th Apr 2020, 3:57 pm | #15 |
So if this is a MW only radio, how does that elaborate dial work?
Do the large numbers refer to a band-spread switch, and if so, why do the lower two scales each have two numbers, and why no scale '1', Is that for a PU input? And no wavelength or frequencies, just station callsigns, was that normally done?
-- Graham. G3ZVT |
26th Apr 2020, 4:15 pm | #16 |
The tuning scales are divided up by states, so you only need to look at the section for your state. The smaller states like Tasmania usually share a division with another less populous state, while biggies like NSW or Vic have their own. Tuning scales do normally have a frequency scale at the top or bottom though.
Remember that Australia is very big and far from anywhere else, so the chances of receiving anything foreign on MW are quite remote. Some dials do have a section for NZ in case anything makes it across the Tasman. There seem to have been more short superhets made in Oz than Europe, presumably because you could only hear the stations from your local city no matter how sophisticated the radio was, and a short superhet was adequate. They used SW to cover rural areas. |
28th Apr 2020, 11:31 am | #17 |
I've just seen this thread. I can provide a circuit diagram for that radio no problem.
P |
1st May 2020, 10:21 pm | #18 |
Thanks Peter,
I managed to get one from Trevor as well. Anyone know how common this model was? Do you think there is much chance of me finding a case for the radio?
2nd May 2020, 9:04 am | #19 |
Re: Can anyone identify this radio (Stromberg Carlson Maestro 4A20)
I'd say the best bet is to keep an eye out on ebay for a complete one.
3rd May 2020, 10:38 am | #20 |
If I cant find the exact case for it then I am tempted to buy an empty wooden radio shell for $50 and mount it in that instead.
Wont be original but still be nice as a working radio. If that were to happen I would also be tempted to throw an FM stage in the cabinet and switch it through the phono input.
If only he could have used his evil genius for niceness instead of evil. Max Smart 18 Sept 1965 Last edited by AC/HL; 3rd May 2020 at 5:52 pm. Reason: Ebay rules |
