13th Nov 2014, 3:45 pm | #1 |
Early digital kit? Anyone ID, comment please?
I've just acquired about 30 of these boards, along other kit from early digital days, and 70s onwards transistors, ICs and passives...
I'll probably post more pix once I've been through the cache. The owner, I understand, was a farmer who, by the looks of things also designed some of his own control equipment. Anyone shed any light on what this repetitive assembly of diodes was used for, and a date? I'm intrigued by the veroboard layout.
Al |
13th Nov 2014, 4:06 pm | #2 |
Re: Early digital kit? Anyone ID, comment please?
Looks like a ROM of sorts.
13th Nov 2014, 4:17 pm | #3 |
Did the farmer have cows ?
John. |
13th Nov 2014, 4:32 pm | #4 |
13th Nov 2014, 4:42 pm | #5 |
Hi John, I only have basic details... he was near Leeds. Serious collector of vintage parts. He had a stroke and suffered some serious loss of movement hence can't make stuff any more.
Al |
13th Nov 2014, 4:53 pm | #6 |
Hmmm, interesting. I'm curious though. The work is to a high standard but it doesn't look like industrial production and is on verboard. Early prototype?
Late 'sixties maybe or later? There is a lot of stray inductance in the long component leads.
Al |
13th Nov 2014, 5:27 pm | #7 |
I once had to replace keypad on some ones milking machine circuit board c1970. A new board would have been expensive as it was new technology. I wonder if he was making his own, or was it an automatic feeding system for cows. These were just becoming available around the same time, one set for each cow would be needed. Are there any relays or solenoids among the boards?
John. |
13th Nov 2014, 6:08 pm | #8 | |
Here is some more of the kit, and yes, there is some sort of timing device with a relay. There's also an alphnumeric counter with Nixie tubes, one board for volume and one for price. And also pictured are some sort of monitors with 4 channels, wiring loom to a very high standard.
Al |
13th Nov 2014, 6:10 pm | #9 |
That old veroboard is probably collectable in its own right!
13th Nov 2014, 6:22 pm | #10 | |
13th Nov 2014, 6:55 pm | #11 |
Post#8 , photo 3 could it be an electric fence unit? Reasoning ...the pot cores one driver/ oscillator and an output. I presume the red, white and green wires go to the O/P transistor. Is the blue cap a high voltage type (1 kv or so) low capacitance. The power supply is on the left O/P 12 volt?? unit designed for car battery now used on 230v
14th Nov 2014, 7:41 pm | #12 | |
14th Nov 2014, 8:35 pm | #13 | |
They were once commonly used in older electronic controlled petrol pumps along with the flat version known as the Minitron. I do know of a few petrol stations still using them. David |
14th Nov 2014, 11:17 pm | #14 | |
Just so everyone knows, I am going to collate all these replies and copy them to the now extremely disabled farmer who gave me the kit. It would mean so much to him to see all these reactions. I love the depth and breadth of knowledge on this forum, and how we can sometimes also be part of a wider community.
Al Last edited by Al (astral highway); 14th Nov 2014 at 11:22 pm. |
15th Nov 2014, 12:41 pm | #15 |
Hi Astral highway ,
if you want to date these boards the chips should have date codes on them. regards S-W |
16th Nov 2014, 10:53 pm | #16 |
I would say the display boards date from the 1970's, although as short wave says check the date codes on the IC's, the Numitrons may have date codes on them too, assuming they are the originals, are they soldered to the board?
Numitrons were developed by RCA, here is an article I found online from Popular Electronics magazine March 1970. http://www.decodesystems.com/numitron.html And an advert from June 1974. http://upload.wikimedia.org/wikipedi..._June_1974.jpg Here are some pictures of a Gilbarco Highline 1 pump Numitron display board that was rescued by my brother, who is interested in vintage petrol stations. The Apollo tube has a date code of 89, the pump logic boards (not shown) use 74 series IC's & date from the late 1970's. The last picture shows a few still in use. Hope this isn't too off topic. David |
16th Nov 2014, 11:31 pm | #17 |
17th Nov 2014, 3:44 pm | #18 |
Hi David, that's really interesting. Yes, the numitrons are soldered to the board. Yes, they numitrons are soldered to the board.
I'd love to do something with these!
Al |
17th Nov 2014, 5:08 pm | #19 |
17th Nov 2014, 6:04 pm | #20 | |
I don't have direct contact but this friend will be passing on any comments and I hope to get his feedback eventually, even if indirectly. Of interest to forum members, shown here now are hundreds and hundreds of early silicon and germanium transistors and diodes, also in the farmer's storage boxes. I want to keep much of the collection intact, but will get round to referencing some of these devices and will be happy to see if I can help if someone is looking for something relevant. I won't be able to catalogue these quite yet, however! More stuff to come as and when I get a moment...
Al Last edited by Al (astral highway); 17th Nov 2014 at 6:22 pm. |
