19th May 2021, 5:52 pm | #1 |
Where next for this Lecson Preamp noise problem ?
I am trying to find the source of excessive noise on a Lecson AC1 preamp.
It's of the 'rustling and thumping' type rather than a gentle white noise. I am leaning towards it being a problem with one of the FET's which controls input selection. Here is my logic ( see circuit extract ) With no inputs selected at all the noise is present, but only on the LH channel. As expected, the noise increases when either phono input is selected as FET switching adjusts the feedback loop to increase gain and apply the RIAA equalisation. To try and isolate the input amplifier itself ( used for all inputs including phono ) I have grounded the junction of R84 and R86, when the noise disappears. This leads me to think that it is generated by one of the FET input switching transistors. Unfortunately, all the output of the devices are summed to provide the input to R84. The following readings seem incorrect: At the point marked 'T9' on the RH channel the voltage is 0v as stated. ( within a few mV ) same point on the LH channel measures - 1.05v approx. For any input not selected, the voltage at the T1, T2, T3 etc. points is -15V EXCEPT that for the PU 1 input its only around -8v. This voltage is common to both channels so it's hard to see whether this is relevant, but it seems to be the only one that's incorrect, other than the -1.05 stated above. I can't see an easy way to determine which of the FET input switches may be noisy, ie TR1 through 13 ( LH channel numbers only ) assuming that this actually the cause. I am also hampered by a complete lack of any PCB layout information, so pairing circuit references with the physical component is a nightmare. I'm rather stuck !! Any thoughts welcome..... Andy |
19th May 2021, 6:40 pm | #2 |
Re: Where next for this Lecson Preamp noise problem ?
Do you have any test gear? Like an oscilloscope?
There are dotted lines that suggest that the input switching is on a different board to the gain stages. How is that connection made? Is it soldered, or via a plug and socket arrangement? Craig |
19th May 2021, 6:46 pm | #3 |
Thanks
The whole preamp is constructed on a single PCB ,with tracks on both sides and some through board connections . It's also extremely densely packed so tracing and measuring anything is very trying. Yes, I do possess a scope. Andy |
19th May 2021, 6:51 pm | #4 |
Peering at some poor quality schematics, two of the options for the switching FETs are BF244 and UC734 - both of which are RF jfets. Not sure why they chose RF devices, other that they might have had low on resistance, and hence good for switching.
But such devices are somewhat sensitive to damage, and to self oscillation. Craig |
19th May 2021, 7:15 pm | #5 |
The careful application of heat or cold to the suspect devices may well give a clue. A dab of meths is more easily localised to one component than freezer spray and maybe enough. A hot soldering iron, briefly applied is a good heat source. I have had resistors, caps and active devices all cause such problems so try them all !
24th May 2021, 6:03 pm | #6 |
These are not good even when working properly IME.... I recall measuring one to be about 3dB down by as low as 14KHz!
24th May 2021, 8:11 pm | #7 |
I use that sort of FET switch in a breadboarded preamp here. It hasn't been very reliable. The very high value resistors to bias the gates and not load the bootstrap circuits (10 megohms) seem to keep going high and need a new set about every 10 years.
I used 2N4391 30 Ohm channel resistance JFETs 14kHz, -3dB? But I thought this was one of the earliest Boothroyd-Stewart designs, and I would have expected something so poor to have been noticed. There's something odd, somewhere. David
24th May 2021, 8:18 pm | #8 |
That's an expensive FET David! They make good CCS when you need several mA from a floating CCS.
I was shocked at that poor performance also yes. It was about 15 years back but I recall ruling out any fault and that it seemed to be a design issue... |
24th May 2021, 11:44 pm | #9 |
They were the standard analogue switch FET at HP. I can still remember the part number 1855-0020. the 2N4391/2/3 were a family of progressively higher Rdson devices (reducing Idss) They were about 20 cents then.
Only years later did I learn that Marconi used them as RF amplifiers at HF in their monumental H2900 receiver (aka 'Sosin's Folly') They make a very good low distortion audio switch with that trick of bootstrapping the gate to the input, and feeding DC bias to the gate via a big resistor. It was a circuit Bill Miller showed me. David
25th May 2021, 4:59 pm | #10 | |
Interesting that they were used as RF amp. I've used the linearised FET idea a few times as voltage controlled attenuators for compressors or VOGAD. |
26th May 2021, 4:56 pm | #11 | |
Looking at the manual this jumped out:-
If these are present I'd see them as a primary suspect. Cheers |
26th May 2021, 5:33 pm | #12 |
Useful thoughts thanks
The noise is more of a rustling or ‘thunder-like’ noise than a crackling Very akin to the din a noisy EF86 can make I’m still desperate to obtain a PCB overlay . Someone somewhere surely has one ? According to the circuit diagram I have, as well as a multitude of series FET switches on the inputs , there are also 4 additional ones across the two disc inputs which would be my first suspects, but I Can’t locate them anywhere on the PCB. All The FETs fitted are type ‘LECSON 6’ and have a green/white package and gold leads so easy to identify. I’ll refer back to my original post here fir a sanity check : ‘To try and isolate the input amplifier itself ( used for all inputs including phono ) I have grounded the junction of R84 and R86, when the noise disappears’ Would the consensus be that this eliminates the input amplifier as the source of noise ? Andy |
20th Jun 2021, 12:31 pm | #13 | |
Craig |
