28th May 2020, 8:34 pm | #61 |
Re: When did tuning dials change from Metres to kHz?
I always liked the Radio1 247 jingles; years of following the Radio1 Road Show around coastal towns like Lowestoft, Filey, Paignton, Weston-Super-Mare - and once actually getting on-stage to guess the "Smiley-Miley" mileage contest [photographic evidence exists of me-and-DLT to support this, but I failed to guess the right mileage] must have damaged me.
Pragmatically, I always wince when radio-stations announce themselves as "97 to 99 FM" without specifying the units. |
28th May 2020, 11:50 pm | #62 |
Reading confusingly had a radio station called Two-Ten FM, which was the frequency in metres of the original ILR when it started on MW.
29th May 2020, 9:08 am | #63 |
Without wishing to hijack, I suppose another question to add to the original post could include, when did some FM receivers have 'Log' on their dials?
I don't have one to hand, but at work my daily driver in the lab is a Leak 2000, which for FM I think goes from 0 to 10(?) it also has the usual units we're familiar with today. Curiously, not all Leak 2000's had this feature on the dial. Another unit, not to hand, is the only music centre I have, a Winthronic 'President' which also has a Log scale. Perhaps a 70's thing? Mark
Slowly turning the 'to-do', into 'ta-dah' |
29th May 2020, 10:34 am | #64 |
More of a throwback to the early days of wireless when the only scale was a logging one. Often 0-100, sometimes 0-180 (degrees of condenser rotation). You could record station dial positions in your reception log for posterity or at any rate convenience- especially if the set was one with multiple (unganged) tuning stages!
The HRO was a notable logging scale only (0-500) set though it did provide frequency conversion graphs on the individual coilpacks.
29th May 2020, 4:45 pm | #65 |
A random page from an old logbook of mine showing the logging scale degrees and position of the band-switch of my R107 receiver.
-- Graham. G3ZVT |
29th May 2020, 5:05 pm | #66 |
Yes, 'logging' scales are part of pretty much every communications-receiver; for example my Eddystone 840A has two!
One being a linear scale (paradoxically calibrated 0 to 2500) along the bottom of the main tuning-window, the other being a small rather higher-geared circular one visible through a small cutout in the top of the tuning-scale, which is calibrated 0 to 100 So you can set the linear one to, say, 650 as a rough indicator then keep on tuning to get the little one to read 85.... |
