11th Jan 2022, 7:51 pm | #21 |
Re: German one-valve superhet FM tuner
11th Jan 2022, 8:22 pm | #22 | ||
http://www.r-type.org/articles/art-011.htm In the cascode example, the upper triode has grounded grid with a neutralisation capacitor is used not for better stability but to increase signal-to-noise ratio. |
11th Jan 2022, 8:27 pm | #23 |
Some associated discussion here: see the "FM in Germany" part about half way down.
https://www.cool386.com/fremodyne/fremo1.html
11th Jan 2022, 9:15 pm | #24 | |
Here are more examples of German UKW tuners with varieties of designs: http://www.jogis-roehrenbude.de/Oldi...KW-Vorsatz.htm |
12th Jan 2022, 12:29 am | #25 |
I have powered it up. It is working. The oscillator only works with at least B+ of 220v drawing total 5ma for both plates.
I have measured the primary inductance of the IF coil to be 9.996 microHenries. I notice that there is a capacitor in series with the bottom of the primary IF to the cathode of the second ECC85 triode. I think it is labelled as C13 (not 100% sure as the scan quality is not good). C13 = 120pF, Assume the "dynamic" inter-electrode capacitance between the anode and cathode to be Cakd under working conditions, then the overall capacitance C to resonate at 10.7MHz with L = 9.996 microH is C = 22.133p. 1/C = 1/Cakd + 1/C13 Solving Cakd = 27.138pF assuming the series cap is labelled C13. This ballpark figure ignores the distributed capacitance of IF coil windings which can be significant at VHF. Typically, the value for resonator caps for 10.7MHz IF transformers is about 10pF to 30pF. This value is compared with the "cold" unloaded Cak = 0.17pF ( or 1.2pF cathode including heater and screen) listed in the ECC85 datasheet. Please correct me if the calculation is wrong. Last edited by regenfreak; 12th Jan 2022 at 12:46 am. |
12th Jan 2022, 1:52 am | #26 |
When I was an apprentice, or maybe even earlier, I built the front end of a "Fremodyne Four" in a spare space on a 5 watt audio amp chassis I had built previously. We had no FM broadcasts out of the capital cities, but when TV arrived, there was one channel right in the middle of the FM broadcast band. It was later moved to a higher frequency. But the tuner worked, though it had 10 % distortion. I didn't have enough knowledge to solve the problem at the time. The "Fremodyne Four" was published as a project by the Australian "Radio Television and Hobbies" or "Electronics Australia" which it became later. A work colleague bought everything I had built during that period, but I have been thinking for a while, of rebuilding the project.
12th Jan 2022, 2:15 am | #27 |
Related question that I've wondered about for years - what is "oscillator squegging"? Can anyone explain it in something like layman's terms?
Mike |
12th Jan 2022, 6:12 am | #28 | |
The T2000 series of the same era had a 12JN8 triode pentode single-valve front end, with pentode as RF amplifier and triode as autodyne mixer. A solid-state diode was used for AFC. The RCA RC1210 series FM-AM chassis had a 17C9 double-tetrode single-valve front end. All of the above had three-gang FM front ends. Cheers, |
12th Jan 2022, 9:10 am | #29 | |
Frank |
12th Jan 2022, 9:56 am | #30 |
Oscillators use RF feedback in their operation. The feedback may be obvious on the circuit, but in many oscillators it operates invisibly via internal capacitances of valves and transistors. It is positive feedback and has a side-effect on how the oscillator starts and stops.
Wind up the HT voltage on an oscillator and at some point it will start up. Wind up a bit more HT and yoou may find it starts more quickly, and the output may be a little larger. Wind down the HT, and the output will diminish, but at some point it suddenly stops. Try increasing the HT from this point, and it does not restart until a noticeably greater HT voltage is reached, the same one we saw in the start-up test. There is hysteresis! There is a range of HT voltage where the oscillator may either be running or not - depending on its pre-existing status. Circuits with hysteresis can make 'reflex oscillators' Think of the simple neon bulb oscillators. An HT supply feeds a capacitor via a large-is resistor. There is a neon bulb across the capacitor. The HT supply is greater than the neon bulb's ignition voltage. The capacitor charges up slowly through the resistor, until the voltage is enough and it lights. It now takes current, more current than the resistor supplies to the capacitor becuse we chose the value of resistor to make it so. The capacitor discharges until it gets to the neon bulb's extinction voltage, where the discharge goes out. The resistor current is no longer being upstaged by the now-zero bulb current, so the capacitor starts charging back to the ignition voltage where the cycle repeats. So an oscillator's start-stop voltages make it a suitable substitute for the neon bulb. For reliable oscillation t theRF frequency, the HT supply to the oscillator has to be stiff enough that the current consumption of the running oscillator cannot pull down the HT supply far enough to stop the RF oscillation. Squegging problems come from HT supply impedances going higher resistance than intended. Maybe a dropper resistor goes high, or dry-soldered. Battery sets suffer from rising internal resistance in their batteries as the batteries near exhaustion. So the recipe for squegging or relaxation oscillation is an RC timeconstant, and something exhibiting hysteresis. It can actually be done deliberately in super-regen receivers. Oscillators become hypersensitive to any help or hindrance at both their start and stop points. Super-regen is a shortening of supersonic regeneration. Supersonic used to mean what we now call ultrasonic, to high pitched to be audible. Regeneration meant positive feedback. So a super regen set would burst into and out of self-oscillation at the received frequency (Your neighbours would hate you!) Audio could be extracted from the current demand on the HT. David
12th Jan 2022, 10:42 am | #31 |
Thanks Frank & David!
Mike |
12th Jan 2022, 11:58 am | #32 |
A dictionary's explanation of the word "Squegging"
squegging. "An irregular oscillation characterised by short periods of oscillation punctuated by brief periods of quiescence. Etymology: Uncertain. Possibly from self-quenching." DFWB. |
12th Jan 2022, 12:15 pm | #33 | ||||
https://canadianvintageradio.com/wp-...Motorboats.pdf Quote:
The higher L/C ratio, the higher the impedance but I cannot establish the definitive link between high impedance and higher oscillation stability. I think the Q will drop if L/C is large which seems there is a sweet range of values exist between stable and unstable. If L/C is too low, Q is too high, it may go unstable. Quote:
This channel has 5 part series on super-regen: https://www.youtube.com/watch?v=OiTwY5loqsE |
12th Jan 2022, 12:29 pm | #34 |
From the Radio Museum. The 6C9 and 17C9 double-tetrode and it's application in an FM tuner.
Valve has a special 10 pin base. https://www.radiomuseum.org/tubes/tube_6c9-10pin.html DFWB. |
12th Jan 2022, 1:38 pm | #35 |
Squegging in the sense of super-regenerative receivers is a form of 'self-quenching'.
The basic mechanism of a superregenerative receiver is that the level of regenerative feedback is increased so signals build up to beyond the point at which the system oscillates; the oscillations are then interrupted in a periodic, controlled fashion to 'quench' them; This quenching can be by way of an externally-generated quench signal [usually applied as DC pulses to the grid] or the superregenerative stage can be 'self-quenching'. In this mode, the RF oscillations build up to a high amplitude, but are rectified by the diode action between the grid and cathode; the resulting negative DC potential charges the grid-capacitor to a sufficiently high DC value that the valve is cut-off and oscillation is blocked. The DC on the capacitor then leaks away through the grid resistor until the voltage falls to a point where the RF oscillations can start again. But they add negative voltage to the grid, so the oscillation stops.... wash,, rinse, repeat. You have two time-constants: the RF oscillation time-constant set by the L/C tuned-circuit, and the second time-constant set by the vales of R and C in the grid-circuit. So the 'thing' oscillates at two frequencies; the low-frequency blocking of oscillation by the DC bias gives the quenching needed. The low-frequency part is the squegging; see also 'blocking oscillator' whih were at one time used extensively in TV timebase circuitry.
12th Jan 2022, 6:13 pm | #36 | |
I tend to shy away from super-regenerative receivers in favour of more complicated superhet topology. I dont really find it easy to tune and pleasant to listen to. Sensitivity is rather poor. However I heard EF95 or 6AK5 VHF pentode gives the "smoothliest" tuning experience. |
13th Jan 2022, 2:49 am | #37 | |
Cheers, |
13th Jan 2022, 10:23 am | #38 | |
6kj8 is rather unique and with one triode optimised for Rf and other for oscillator. Last edited by regenfreak; 13th Jan 2022 at 10:41 am. |
13th Jan 2022, 10:40 pm | #39 |
I forgot that I built this one-valve minimalist FM supehet the year before. It cannot get more simple than this and it was my first working FM superhet with a pentagrid convertor 6SB7Y. I had lots of success building a MW supehet using 6SBY7 for its outstanding DX performance.
It works well with an external antenna. For indoor antenna, I would need a 20dbm LNA pre-amp to pick up all the stations. Obviously it is noisier than miniature triode valves but it happily oscillates all the way to 97.3MHz, super stable ( I use 10.7MHz below) |
14th Jan 2022, 4:58 am | #40 | |||
Cheers, |
