9th Jan 2022, 4:06 pm | #1 |
Capacitor value?
Hi Guys
Can you tell me how to read the value of capacitor attached? These I believe were used in a lot of Philips tv radio sets in the 80's Many thanks technotel |
9th Jan 2022, 4:21 pm | #2 |
Re: capacitor
https://www.elprocus.com/capacitor-color-code/
Eg: The 1st one in your photo: 100,000pF (0.1uF) +- 20% 100VDC max. working voltage. Lawrence. Last edited by ms660; 9th Jan 2022 at 4:38 pm. Reason: whoops. |
9th Jan 2022, 4:31 pm | #3 |
Re: capacitor
9th Jan 2022, 4:33 pm | #4 |
Re: capacitor
Mullard C280 range - commonly known as 'tropical fish'.
You'll find the colour code chart here, which explains how to determine the capacitance, the tolerance and the working voltage: https://www.elprocus.com/capacitor-color-code/ They're not normally troublesome unless the leads break off at the ends if under mechanical stress. Hope that helps.
9th Jan 2022, 5:41 pm | #5 |
Re: Capacitor value?
The holes in the PCB seem to be too far apart.
That may put a mechanical stress on the capacitor and any future replacements. |
9th Jan 2022, 5:54 pm | #6 |
There appears to be a crack on the right hand side of the first tropical fish capacitor in the photo.
9th Jan 2022, 9:54 pm | #7 |
There's a huge chunk missing from the right hand one!
Regards, Ken. BVWS member Last edited by Kentode; 9th Jan 2022 at 9:54 pm. Reason: Typo |
10th Jan 2022, 11:29 am | #8 |
Thanks guys for all your great comments and tips and links. Learned alot about these caps. Yes several have cracked and bits come away. I will replace them now I know how to value them.
regards all technotel |
