Old 17th Jan 2022, 12:35 pm   #1
6SN7WGTB
Default Bush DAC90A - dial pointer colour? If any...?!
Just restoring one of the above.
I'm intending to respray the dial lamp 'reflector' white, and may replace the aged and yellowing translucent panel.
The dial pointer obviously just needs to be dark to show up, which it is as it's a bit rusty looking!
However, trivial though it is, was the pointer any specific colour when new?
It might just be where the rust has rubbed, but I think I can detect a faint red bit on the flat top part...?
6SN7WGTB is offline
Old 17th Jan 2022, 1:05 pm   #2
Ian - G4JQT
Ian - G4JQT's Avatar
Default Re: Bush DAC90A - dial pointer colour? If any...?!
Yes, red.
Ian - G4JQT is offline
Old 17th Jan 2022, 1:13 pm   #3
6SN7WGTB
Originally Posted by Ian - G4JQT View Post
Yes, red.
Thanks Ian, might as well do that while in there.
6SN7WGTB is offline
Old 17th Jan 2022, 3:22 pm   #4
Cobaltblue
Cobaltblue's Avatar
That's unusual I don't think I have ever come across a DAC90A that had a rusty pointer like that, even when they were totally corroded wrecks.
Was the dial glass missing?
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 17th Jan 2022, 8:47 pm   #5
DonaldStott
DonaldStott's Avatar
Humbrol RED Enamel for the Pointer and Halfords Lada Cream for the Refelector.
BVWS Member
DonaldStott is offline
Old 17th Jan 2022, 8:59 pm   #6
6SN7WGTB
Originally Posted by Cobaltblue View Post
That's unusual I don't I have ever come across a DAC90A that had a rusty pointer like that, even when they were totally corroded wrecks.
Mike T
Not at all - it's all in nice condition just the pointer is devoid of colour and very slightly surface corroded.
6SN7WGTB is offline
Old 17th Jan 2022, 8:59 pm   #7
6SN7WGTB
Splendid, thanks!
EDIT: I suspect Lada colours may be almost as old as the radio - I suppose any near cream will do...
6SN7WGTB is offline
Old 17th Jan 2022, 10:20 pm   #8
DonaldStott
Any ‘near cream’ will do but that Halfords Lada Cream is almost an exact match for any vintage valve radios I’ve restored.
BVWS Member
Old 18th Jan 2022, 2:15 pm   #9
6SN7WGTB
Should the engraved lettering on the knobs be highlighted in cream too?
6SN7WGTB is offline
Old 18th Jan 2022, 2:54 pm   #10
DonaldStott
Only if you have a steady hand, a small enough brush and the appropriate paint!
In the past I've used something like this:-
https://www.amazon.co.uk/gp/product/B00GOYMLSK/
BVWS Member
Old 18th Jan 2022, 5:14 pm   #11
Northyorks1
Have had good results using tissue or a cloth to wipe paint over the lettering, then wipe off excess. May take a few runs over to build up but brings good results.
Ian
Northyorks1 is offline
Old 18th Jan 2022, 6:02 pm   #12
Silicon
The original red pointer colour may have faded.
Red paint seems to be more vulnerable than other colours to 'bleaching' in sunlight.
Silicon is offline
Old 18th Jan 2022, 6:49 pm   #13
Ian - G4JQT
I picked out the old paint with soap/water/tooth brush/cocktail stick and repainted with Tipex fluid. No need to be careful cos once it dries rub off the unwanted places with furniture polish and a cloth.
Old 18th Jan 2022, 10:04 pm   #14
6SN7WGTB
It was a bit fiddly.
I cleaned them with a nailbrush as years of grime was in the engraving.
On the Tone knob it showed signs of a more gold-coloured paint, so I opted for a brass enamel from the modelling box.
Nothing that won't tidy up with a buff and shine once hardened.
6SN7WGTB is offline
Old 19th Jan 2022, 10:29 am   #15
DonaldStott
Excellent outcome - well done!
BVWS Member
