11th Apr 2020, 2:33 pm | #21 |
Re: Akai X-200D solid state
The Record indicator I think is the window that sits in-between the 2 VU meters.
11th Apr 2020, 2:38 pm | #22 | |
There IS a record indicator - it's a red bar that should light up between the meters. |
11th Apr 2020, 2:48 pm | #23 |
If switch cleaning doesn't cure the problem and it's nothing else obvious then I would connect a suitable signal source to the line inputs and monitor the line outputs when set to record, if no audio frequency coming from the line outputs then it might be HF oscillation, hard to say for sure.
For signal fault finding I always used a 'scope when I was in the trade...best tool out for that job. Lawrence. |
11th Apr 2020, 4:42 pm | #24 |
I cleaned the rec/play with swich clener and played it gently back and forth ther record light does not light up only light there is is the light for the hole vu unit on the side
11th Apr 2020, 4:44 pm | #25 |
Make sure the record/playback switches move right over when in record mode.
Lawrence. |
12th Apr 2020, 11:05 am | #26 |
So can see that the separate Record lamp is not lighting when Record is selected when you are actually looking inside the unit ? i.e. can you see an unlit lamp.
12th Apr 2020, 2:11 pm | #27 |
Lawrence you were right, the record/play switch was not going all the way over. Slight adjustment and voila now records.
Thanks Lawrence and everyone who helped. |
