13th Feb 2018, 8:04 pm | #21 |
Re: My first frame aerial
I'm also wondering if they could be used on a transmitter. If they perform on transmit as they seem to on rx it would be very impressive. Again though matching might be a problem.
13th Feb 2018, 8:30 pm | #22 |
Small loops actually make poor antennas for both receiving and transmitting. The difference is that for broadcast reception you are receiving a strong signal in the presence of a lot of noise, so a poor (but very directional) antenna can do a good job. The converse happens for transmission - now the noise is at the other end so the weakness of the small loop becomes apparent. This gives the appearance that antenna reciprocity has failed, but it hasn't.
13th Feb 2018, 10:01 pm | #23 |
Be that as it may the loop is giving me clear reception of stations that I want and rejecting all the noise, hash and adjacent channel interference that a 60 feet long wire gives. The loop can also be spun around 360 degrees in seconds.
Of course if I put filters in the long wire to supress the hash (can it be done?) and bandwidth controls on the receiver to try and stop the adjacent channel intereference and found some way to make the 60 foot long wire go in the direction of my choice I might achieve the same thing as the loop seems to be doing. You can't do much with a long wire either, just put it up and that's that. The loop is much more fun to play with |
13th Feb 2018, 11:19 pm | #24 | |
With the assumption that a frame aerial has a coupling winding, where the tuning cap. is wired across the main winding, you will have a feeder from that coupling loop to the radio. Since the main winding is a balanced-to-ground affair, (it's important to preserve that) you need a balanced transmission line to connect from the coupling winding to the radio, which will need a balanced aerial input. (Failing that a balun will be needed *). That line will be low-Z, so the tuning cap. must be across the main loop (which will be high-Z) - thus remote from the radio. As for it being outside, obvious considerations apply. Site it away from earthed objects - especially metallic things - and ensure that the loop - wire, woodwork and tuning cap. - are well protected from harsh weather, incl. strong winds. * Once, I owned an Eddystone 730/4 comms. radio. That did not have provision for a balanced aerial. However, I was able to re-engineer it so that the coupling windings on the aerial input cols had each earth end lifted up from ground and taken to a separate terminal, thus providing a balanced input. OTOH, the Eddystone 888A which I also owned already had provision for a balanced aerial. The point is this: if your intended set doesn't have a balanced aerial input, before getting involved with baluns and such like, see if you can modify the proposed radio. A domestic set should be much easier to modify than a six-range comms. radio like the 730/4. Al. |
13th Feb 2018, 11:26 pm | #25 |
Maybe I'm just lucky but I'm feeding the coupling coils output straight into the A and E sockets of an A22 (via 15 inches of twisted flex) and it's working fine. I'll try adding a balun when I get around to it and see what difference it makes or if there is any improvement.
13th Feb 2018, 11:38 pm | #26 |
ISTR that the essence of maintaining a balanced (to earth) arrangement is that by so doing you maximize the depth of the null. The polar diagram for max. signal may also become asymmetrical if the balance is upset.
And, just for what it's worth, I recall that many years ago, I discovered that common twin flex (such as what you are using) has a Zo in the vicinity of 75Ω. Al. |
13th Feb 2018, 11:42 pm | #27 |
Would it really need a balanced input, Al? Connecting the coupling winding to an unbalanced input would simply mean the coupling winding had a ground reference, but as there is no connection to the main tuned winding (other than by a small stray capacity) it shouldn't upset things as far as I can see. The feeder could be coax.
Andy G1HBE. |
14th Feb 2018, 12:02 am | #28 |
Thanks for the input all. IÂ’ve just realised that I took a JVC hifi with one of these modern mini loop a.m. loops on it to the tip a couple of weeks back. No doubt it would have had parts for a balum in it. I will be using coax as soon as I can get to Maplins to buy the fittings. How will this affect the need for the balun?
14th Feb 2018, 1:05 am | #29 |
I suspect that a long length of any low impedance feeder between the loop's coupling loop and the set without some stepdown/stepup transformer at each end will not work brilliantly. A traditional aerial/earth input will be rather higher impedance.
300R ribbon feeder might do quite well....... perhaps with a 1:1 TX at the receiver end to keep it balanced. I've got a reel of it somewhere, hmmmmm.....
14th Feb 2018, 2:02 am | #30 |
Thanks. The original plans show coax connected directly across the coupling coil so presumably any matching must be done at the radio end. Can I build the balun myself or do I buy it? A quick look on the internet shows they are band specific with not many mw
ones and also somewhat pricey. Last edited by Boom; 14th Feb 2018 at 2:03 am. Reason: Half asleep |
14th Feb 2018, 10:03 am | #31 |
Strictly speaking it's a n un-un you need as the coax is unbalanced and so is the radio's input. You could try it without at first and if it works to your satisfaction the job's done. If the gain seems a bit low, then a step-up transformer wound onto a ferrite toroid will improve the match.
Andy G1HBE. |
14th Feb 2018, 1:10 pm | #32 | ||
I am not knocking loops. They can be very useful for reception under poor conditions. I am just pointing out that their advantages for reception are not because they are good at receiving wanted signals, but because they are quite bad at receiving unwanted signals (local noise, off-channel, other directions). This means that their usefulness for reception does not translate into usefulness for transmission. |
15th Feb 2018, 1:44 am | #33 |
Type of feeder with a frame / loop aerial.
Earlier, I advocated my understanding that for the optimum results with that type of aerial, a balanced feeder was the best (but not the only) choice. My personal thinking about that goes along these lines. 1. The loop / frame aerial with its tuning capacitor, but not connected to a feeder, is a balanced aerial: it has no connection to earth / ground, etc.* 2. In that sense, as an aerial, it is similar to the classic centre-fed half-wave dipole, without a feeder attached. 3. It is widely accepted - and with good reasons - that a dipole aerial should be fed with a balanced transmission line for optimum results. 4. A consideration of 1, 2 and 3 above strongly suggest therefore that a balanced feeder should likewise be used with a frame / loop aerial for same reasons. *Strictly speaking, that is not exactly true, of course. 1. There will be some capacitive coupling from each lower part of sides of the frame aerial to ground. And that capacitive coupling will be less at the top of the side windings. However, if the frame is carefully constructed to be physically symmetrical, left and right sides, those capacitances will be equal, thus the balance to earth / ground will be maintained. 2. A typical ex-broadcast receiver tuning capacitor is not a balanced variable capacitor: it is not constructed to be physically symmetrical, although I would expect that lack would have only a very minor 'unbalancing' effect. However, that does not hold when that capacitor is adjusted (for obvious reasons). I would expect 'Hand-effects' to disturb the optimum settings for elevation and azimuth. But how much? I wouldn't like to predict! I have added an attachment which is of some relevance and interest. I believe I scanned it from an old PW magazine which I was given a long time ago. Note that this author specifies 300Ω balanced line. Just a few thoughts: my attempts to develop this fascinating thread. Al. |
15th Feb 2018, 2:19 am | #34 | |
No Longer a Member
If you tap into just one turn at the earthy end (coax braid connected to it and the V/C frame) the impedance and loading effects are low and you can lower it further with a matching transformer (as I do for my transmitting loops) then you can pipe the signal down standard 50 or 75R coaxial cable and transform it up at the other end to suit the radio. One other trick that could work, if the match wasn't critical just for receiving, since a single turn of the loop has an impedance around a few hundred ohms or more, you could simply use vintage TV 300 ohm ribbon cable (if you could get it) connected to a turn of the loop, feed that to the radio with a 1:6 ratio step up broadband transformer at the radio end terminated with about a 10k resistor at the radio end (or similar) would work. You could probably get away with 5 or 10 meters of this cable as the losses are fairly low. |
15th Feb 2018, 10:16 am | #35 |
Argus - surely any direct connection of a feeder to 'one side' of the loop would ruin the balance, spoil the null and bring about the 'antenna effect' in which the loop begins to act as just a random wire?
I still say a single-turn coupling loop (floating) fed with coax should be fine. A step-up ferrite transformer at the receiver may be necessary if the radio has a high input impedance.
Andy G1HBE. |
15th Feb 2018, 8:04 pm | #36 |
I'd feed the coupling-loop down a length of 50/75-Ohm coax, with the outer going to the earth-terminal on the radio itself.
But that's because I'm conditioned to using radios designed for 50/75-Ohm antenna feeds. Interposing obscure baluns etc. in the signal path can only result in signal attenuation - which means the radio's AGC will wind the gain up, so bringing background noise/RFI up as well! Contextually, I'm wondering if, for MW reception, there could be a place for something like the noise-blanking system used in US WWII aircraft where they phased the signal from the main antenna against the signal from a 'noise antenna' that was deliberately sited in amongst the spark-plugs of the Wright "Cyclone" 24-cylinder radial engine... |
15th Feb 2018, 8:12 pm | #37 | |
Andy G1HBE. |
15th Feb 2018, 11:33 pm | #38 | |
No Longer a Member
I have done much more work with loops as transmitting devices for pantry transmitters than receiving loops for vintage radios. In fact I do not have any receiving loops, only transmitting ones. When the loop is in receiving mode though, it is sitting in the far field from the radio station's transmitter. At that point the ratio of electric to magnetic field has settled out at 377 ohms or 120pi Ohms. The loop responds primarily to magnetic part of the field. Therefore, in theory, if you grounded any part of the loop electrostatically, one end, its center or near one end, it wouldn't affect the function of the loop as a magnetic receiving antenna. As an electric field receiving antenna, the loop as pointed out, is very poor. In the case of a loop for a transmitting antenna, I'm confident the magnetic radiation pattern emerging from the edges of the loop, in the plane of the loop, is unaffected by connecting one end of the loop to ground and the coaxial sheaths of cables and other equipments. This is because it it merely an electrostatic connection and doesn't alter the magnetic fields. In the near field, the magnetic component of the loop's output is high and the electric field very low. When it comes to extracting energy from a loop, or injecting it for transmitting, I think alterations in the weak electric field by unbalancing part of it would probably not be noticeable, that is if you were receiving the signal with a transistor radio with a ferrite rod. Simply the lower loop turn acts as a coupling coil into the main loop, and if the impedance is transformed correctly, the current in the coupling turn is maximized at the operating frequency. It is a case of "inductive link coupling" into the main resonant loop, so you don't really regard the coupling turn as part of the "main tank circuit" (you could isolate it if you wish as a separate coil one turn coupling coil and not a tap on the main resonant winding) and ideally in this coupling circuit, at resonance, the reactive elements cancel and maximum energy is transferred to the loop and when those conditions are correct it also matches the line impedance. For my transmitting loops, I have arranged all of them with 50 ohm input impedances. That way I can use my 50 Ohm coax cables, use 50R RF power meters for forward & reflected power meters, SWR meters , 50R dummy loads to check my transmitters, etc and have the loop more remote from the transmitter if I want. |
16th Feb 2018, 1:08 am | #39 |
What is the input impedance of a typical new "hifi"- the sort that comes with a small external loop aerial?
John |
16th Feb 2018, 1:23 pm | #40 |
I have sourced some torroids from Ed_Dinning. Can anyone let me know how many windings and turns to wrap around it and what connections go where?
Thanks |
