Old 20th Jul 2019, 10:18 pm   #1
humphrey
Default ACER radio
I just bought a thirties radio at a vide grenier for three Euros. There are no valves or speaker and I have not been able to find a schematic. It has three knobs and has a vertical gothic appearance with a semi circular dial. There are seven valves 27,24,58,57,47 and what looks like two rectifier valves 32 and 80
The nearest I can find is here https://www.doctsf.com/a-c-e-r-model.../f46625/ori=ps The case is identical
I believe that most valves have 2.5v heaters with 80 that is 6.3v
humphrey is offline
Old 22nd Jul 2019, 9:14 am   #2
Herald1360
Herald1360's Avatar
Default Re: ACER radio
80 has 5V filament.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 22nd Jul 2019, 10:56 am   #3
humphrey
That is true as you say but I was measuring the actual voltage at the socket.
I am having second thoughts now as all the valves are missing and replacement of them is bound to be very expensive. I now realise that the missing valve label with the UX4 base would be a triode possibly 10 or 20.
I have not been able to find a schematic either. It is a pity as it is an impressive looking case. Finding a set of reasonably priced valves would be a bonus. Thank you for your reply Chris.
humphrey is offline
Old 22nd Jul 2019, 11:08 am   #4
Mike. Watterson
I'd not worry too much about the schematic unless it's been "got at"!
The valves is a trickier issue.
Mike. Watterson is offline
Old 22nd Jul 2019, 11:49 am   #5
humphrey
The loudspeaker and output transformer are missing and there is no trace where it may have been wired from.
humphrey is offline
Old 22nd Jul 2019, 7:12 pm   #6
Herald1360
Herald1360's Avatar
Well the output TX primary will connect between the output valve anode and HT+. Probably the smoothing cap + rather than reservoir cap + on an old set like this. Speaker to the secondary of the TX. Setup could be complicated if an energised field speaker with the field either in series with (as a filter inductor) or across the HT was originally fitted, in which case modifying the set to a PM speaker and adding a suitable resistor might be needed.
Cost of valves may make this uneconomic to repair...... maybe just polish it up as a display piece?
....__________
Old 22nd Jul 2019, 7:21 pm   #7
Ed_Dinning
Knowledge of the output valve should enable you to get the correct transformer
Given the speaker size/ fixing centers should get you a suitable one from one of the members via the wanted ads unless it is a very slimline unit you need.
Does it have a choke or big smoothing resistor or does it need an energised speaker.
Ed
Ed_Dinning is offline
Old 22nd Jul 2019, 8:43 pm   #8
humphrey
Sadly, the cost of the replacement valves will preclude the restoration of this early wireless. The only way out of this is to preserve it "as is" and install a seperate bluetooth module and amp. Unless I can get the valves at a good price. Any leads would be welcome.
humphrey is offline
