Old 14th May 2018, 12:29 am   #1
Kevmitchell
Default Recent HMV Compact Record Player purchase
A new venture for me, having loved music all my life I've decided to purchase and restore an old classic. I found this fabulous compact HMV record player in a local vintage store and decided to try and bring it back to life.
I don't know anything about it so any information would be very welcome. Surprisingly there is no I. D. on the case so I have little to go on.
Any thoughts please let me have them
Best wishes
Kev Mitchell
Name:	HMV Compact Record Player.jpg
Kevmitchell is offline
Old 14th May 2018, 9:09 am   #2
ms660
ms660's Avatar
Default Re: Recent HMV Compact Record Player purchase
Looks like an HMV 2126
https://www.vintage-radio.net/forum/...ad.php?t=95676
Lawrence.
ms660 is offline
Old 14th May 2018, 9:35 am   #3
Paul_RK
Paul_RK's Avatar
An older thread includes what may prove a very helpful note on repairing the 'Double C' cartridge:
https://www.vintage-radio.net/forum/...ad.php?t=40489
It doesn't much resemble any other cartridge, so unless you're minded to perform major surgery on the unit you'll be restricted to 78s and mono microgroove.
Paul
Paul_RK is online now
Old 14th May 2018, 10:18 am   #4
Audio1950
Sorry to say that for a first restoration project, you couldn't have chosen a worse model. The cartridge, which is the bit that holds the stylus (needle) is almost certain to be dead, it's well over sixty years old. Replacements have been obsolete for years, as have the conversion kits that were available when the original cartridges became obsolete. No other cartridge will fit, unfortunately. By all means have a go at repairing the cartridge if you get no sound from it, but even if you do get it to work, you cannot play stereo records on it ,as they would be ruined. I hope you didn't pay a lot of money for it, and I'm sorry to be the bearer of discouraging news!
Audio1950 is offline
Old 14th May 2018, 10:42 am   #5
peter_scott
peter_scott's Avatar
If it is the same as the one highlighted by Lawrence then you will need a radio with a "gram" input or some other means of amplifying its output.
Peter
peter_scott is offline
Old 14th May 2018, 2:52 pm   #6
Aerodyne
Aerodyne's Avatar
Well, I personally wouldn't give up on it. It surely would be possible to remove the old cartridge and head assembly and replace it with a headshell from, say, a Garrard deck (assuming one can be found - I haven't looked) or at worst, make some form of carrier to take a stereo cartridge.
I guess it depends upon personal ability, toolkit, patience and ingenuity - and whether it is worth the effort, in the end. Needs its own amp, of course, like so many add-ons of its vintage.
Tony
Aerodyne is offline
Old 14th May 2018, 4:26 pm   #7
Audio1950
When the headshell assembly is removed all that's left will be a hollow tube with a small hole in it. Other headshells are easily obtained (if somewhat expensive), but adapting it to fit that tube would be difficult. If it could be done though, there remains the problem that there is no weight adjustment on the HMVs' arm, so the combined weight of the new headshell, plus the replacement cartridge would have to less than that of the original, existing cartridge, which is unlikely. All these potential problems would hardly seem worth the trouble for this particular record deck.
Old 14th May 2018, 5:14 pm   #8
Hartley118
Hartley118's Avatar
This was one of the earliest means of playing LPs, so is certainly of historical interest. In addition to your 'accessory turntable' for plugging into a radio, the same deck with its 'Double C' head was incorporated into a rather good HMV self-contained record player which featured on Columbia 78 record sleeves. See the attached 1950s picture for period interest from the 'ponytail era'.
You'll find various threads here on the Double C head. In this thread
https://www.vintage-radio.net/forum/...d.php?t=136587 I describe a successful repair.
In its favour is the fact that the element is robust ceramic and not short-lived Rochelle salt crystal. Problematic is the fact that the foil connections give trouble. I did actually succeeed by quickly soldering thin wires to the copper plated ends of the ceramic element instead of struggling with foil.
If you're reasonably handy with careful mechanical dismantling and reassembly, you may well be able to bring yours back to life.
Martin
BVWS Member
Hartley118 is offline
Old 14th May 2018, 7:24 pm   #9
Aerodyne
Aerodyne's Avatar
Martin, your link doesn't work for me.
Tony
Aerodyne is offline
Old 14th May 2018, 7:36 pm   #10
Paul_RK
Paul_RK's Avatar
Tony
Me neither, but copying its thread number into a working link gives
Paul
Old 14th May 2018, 8:07 pm   #11
Hartley118
Hartley118's Avatar
Tony
Paul
Yes, that's the one. Must attend a course on copying & pasting best practice!
Martin
BVWS Member
Old 14th May 2018, 10:18 pm   #12
Station X
Station X's Avatar
You cannot copy a link directly from a post. It appears in truncated form and will not work.
You need to navigate to the actual thread, copy the contents of the address bar, paste them into your post and let the forum software do the rest.
Graham. Forum Moderator
Station X is online now
Old 15th May 2018, 7:51 am   #13
Hartley118
Hartley118's Avatar
Well well. Thanks for that Graham. There's always something to learn!
I hope that my link blunder and its fix might be of value to others too.
Martin
BVWS Member
