13th May 2018, 6:01 pm | #1 |
Earthing.
Question. Mains record player two white leads are the current + and -. Can I earth also?
13th May 2018, 6:22 pm | #2 |
Re: earthing
No.
Lawrence. |
13th May 2018, 6:22 pm | #3 |
Re: earthing
Looks like a none isolated chassis, so called AC/DC with no mains transformer. Is the neutral mains connected to the chassis? If so no, you cannot earth it but a new mains lead with colour coded wires would be a really good idea.
Valves UY85 and UL84? With two white wires it may be connected to the line, be careful it could all be live! |
13th May 2018, 6:31 pm | #4 |
Re: earthing
POSITIVE and NEGATIVE have no real meaning as far as a set connected to AC mains is concerned. It's LIVE and NEUTRAL. NEUTRAL should be connected to chassis, possibly via the mains switch.
13th May 2018, 6:33 pm | #5 |
Re: earthing
Er, pedantic but its Line and Neutral. The line is the live wire.
13th May 2018, 6:34 pm | #6 |
Re: earthing
I'll get me coat.
13th May 2018, 6:36 pm | #7 | |
Re: Earthing.
13th May 2018, 6:37 pm | #8 |
Re: earthing
thanks guys , so what do I do with the earth wire on the 3 core ? and I don't suppose it makes any difference on the pos/negative sides on the switch (see the 2 white existing )cable bob
13th May 2018, 6:37 pm | #9 |
Re: Earthing.
I expect the OP is now thoroughly confused.
13th May 2018, 6:39 pm | #10 | |
Re: earthing
Is the switch actually marked + and - for DC supplies? You must make sure that the NEUTRAL (blue) wire is connected to the chassis via one pole of the switch. Check with a meter on ohms range if you're unsure.
13th May 2018, 7:28 pm | #11 |
Re: Earthing.
thanks for that , the switch has no markings , both supply wires are soldered onto the power switch , would that be OK for the new twin core , ie soldered onto the tabs thanks bob
13th May 2018, 7:50 pm | #12 |
Re: Earthing.
That would be fine, but see previous posts regarding connecting the neutral conductor to the chassis.
13th May 2018, 10:42 pm | #13 |
Re: Earthing.
Also make sure that the set has insulated knobs and that they are in good condition.
13th May 2018, 11:28 pm | #14 |
Re: Earthing.
Although the amplifier cannot be earthed, you can improve safety by earthing the deck metalwork.
14th May 2018, 8:45 am | #15 |
Re: Earthing.
Just wanted to make a safety point. I agree that the neutral must go to chassis via the mains switch - providing that the switch is double-pole (which from the photo this appears to be). In some old equipment only a single-pole switch is provided. In that case, if the neutral is wired to chassis via the single-pole switch, then the chassis rises to mains live potential (via the valve heaters) when the thing is switched off. In that case it is essential to ensure the line is connected via the switch and the neutral direct to chassis or, even better, replace the single-pole with a double-pole switch.
14th May 2018, 11:08 am | #16 |
Re: Earthing.
thanks for the input guys , I think the mains side of the player I will let a professional look at it for me great site very helpfull
14th May 2018, 11:10 am | #17 |
Re: Earthing.
That would seem a very sensible approach if you're not confident about it.
14th May 2018, 1:09 pm | #18 |
Re: Earthing.
You didn't say why you want to change the mains cable. Unless it's damaged there's no legal requirement to change it, assuming the player has not been modified. It should never be operated with any cover removed, and nothing should be connected directly to it.
14th May 2018, 2:43 pm | #19 |
Re: Earthing.
Although there's no legal requirement to change the cable, I would personally feel more comfortable with a live chassis being connected via a polarised one.
14th May 2018, 4:50 pm | #20 |
Re: Earthing.
The three pin plug would ensure that, but a coloured sleeve on the live (line, whatever) would be a good idea. You may find that the cable has silver and gold conductors, but they're not immediately obvious.
