6th May 2018, 9:01 am | #21 | |
Re: Which lube to use?
6th May 2018, 7:51 pm | #22 |
Returning to the original question, does anyone have any idea as to the type of lubricant actually used by Technics? The service manual for the SL-3 doesn't seem to offer any clues.
Alan |
7th May 2018, 9:43 pm | #23 |
if it's anything like the stuff on CD sled rails, it's Molykote, which is a white lithium-in-silicone grease. The datasheet lists its applications as including 'aircraft engines'.
Kevin |
8th May 2018, 1:02 am | #24 |
Molykote is a brand name of Dow, but it covers a very wide range of individual products, so we need to specify something like 'Molykote XYZ'.
Re silicones, a few years ago I had a work colleague who told me that in her previous job (electronics) they had a separate admin building and silicone products (polishes) were banned in there. She didn't say whether or not it was an issue specific to PC's, I just assumed it was a site-wide ban. I stumbled upon another forum recently where the members were having a "frank and lively" discussion about various brands/types of lubricants - in this instance about the lubricants used in the valves of trumpets! One comment that was made that struck me was that in some tests, some favoured products (oils) were found to evaporate to "apparent dryness" within a few days. Of course, that does exclude the possibility that just a thin molecular layer was left behind with really good lubrication properties! B
8th May 2018, 6:42 am | #25 |
Slightly OT, but I used to lube the mechanism of my clarinet with plain old 3 in 1.
And on-topic, recently a friend's CD transport (an old Meridian) drawer was operating erratically. So I cleaned the sled rails and re-lubed with sewing machine oil (see earlier). Problem solved. |
8th May 2018, 1:01 pm | #26 |
Thanks for all the advice.
Sounds like sewing machine oil is a tried and tested non controversial product? Something like this? https://www.prym.com/en/sewing-machine-oil-20ml-611998 Saying this the tone arm sled seems to have been greased rather than oiled. Will the oil be too thin? The various threads I've read recommend using various lubes, greases and oils but it seems to be heavily dependant on personal preference rather than there being hard rules about composition and viscosity. For a beginner who want's to do it right it's difficult to know what to use! |
8th May 2018, 5:08 pm | #27 |
I heartily sympathise. It is also difficult to establish the actual constituents used in the multitude of available lubricants. Have to say that I now tend to take a very simplistic approach and think of thin oils in terms of slipperiness and thicker greases for longevity.
I'll probably be shot down in flames for saying so but I think engine multigrade is a great compromise in very many circumstances. Synthetic or mineral anyone!? Alan |
8th May 2018, 5:37 pm | #28 |
The lubricants specified by the official Philips service manual for my late 1970's cassette deck were W20/50 engine oil for the axles of gears and an ordinary Lithium wheel bearing grease for sliding surfaces and metal gear teeth.
8th May 2018, 6:19 pm | #29 | |
8th May 2018, 10:57 pm | #30 | |
Looks like it is readily available in 100g tubes at less than ridiculous prices. Mike |
8th May 2018, 11:50 pm | #31 |
Lithium soap thickened silicone oil. They say the benefit is that it operates over a wider temperature range as compared with a mineral grease. so -73C to 204C rather than -30C to 170C for mineral.
I'm just going to leave it at that |
9th May 2018, 1:55 am | #32 |
As already said, the best starting point is to ascertain what lubricant the equipment manufacturer used in the first place and/or specified in the service manual. It is reasonable to assume that there was adequate diligence behind that selection, and that as well as doing the primary job, it did not have unwanted side effects. The manufacturer generally does not want warranty returns or loss of reputation because of poor selection of a component – really a consumable in this case.
Failing that, then consider the application. In this case we have a very low speed sliding mechanism that is subject to controlled speed variations as an operational requirement, if not actual stop-start, and which requires precision positioning. The driving power is probably very limited, as well. Very low friction is indicated, but more than that, a static friction coefficient that is lower than the dynamic friction coefficient is required to ensure that there is no chance of even incipient stick-slip. The mechanism is probably somewhat open to atmosphere, so whatever is chosen should be non-attractive to airborne particulates that might adhere to the slide rails with progressively deleterious effect. That points to PTFE as being a suitable candidate. I’d say that there was a good chance that that was what Technics used, but it would be better if we had confirmation on that point. The CD drawer slide-rail case is a much easier proposition. The sliding motion, once started, is continuous; some variation in sliding speed over the course of travel is not an operational problem, although it may be aesthetically undesirable. There is no precise intermediate positioning requirement involved; the end-stops essentially take care of what is needed. Probably enough driving power can be provided to overcome starting friction and any in-service build-up of dynamic friction due to the progressive deposition of airborne contaminants. Anti-stick slip properties are nice to have but not essential. More generally, the lubricants world, at the consumer level at least, is as full of myths, misunderstandings, misconceptions and bad science as is the audio world. It pays to be wary of what one may find on the internet. Cheers, |
