1st May 2018, 2:37 pm | #1 |
Fidelity HF42/45 Volume problems (newbie)
Hi, I am a Newbie so please bear with me.
I have just got my grans old Fidelity HF45 up and running (with the aid of WD40 and a new stylus). The mechanism works well but the volume has issues. 1. There is a hum - It could be a mains hum, or dodgy capacitors - I have ordered replacement bridge rectifier and smoothing capacitor and a few other which I will fit. I can live with the hum but the volume is dodgy. 2. Volume is all or nothing - The volume control is just has a no sound at all (except static crackles and noises) until you get the knob to about half way then there is a millimetre of full volume, the nothing to the other end of the dial. When I turn it off the player at the socket and turn the dial slowly I hear a click just before half way. I can't help thinking it is an issue with the knob itself but as I say I am a newbie with no electrical experience. Can you buy new volume controls if so from where? 3. Tone is practically useless - it has little or no effect on the sound. It does sometime work by dulling the full volume millimetre.... I am assuming the cartridge is fine or there would be no sound at all Question - there is a red, white, green and black wire on the arm. Only two are connected is this correct? Please help. Thanks Ian |
1st May 2018, 5:03 pm | #2 |
Re: Fidelity HF42/45 Volume problems (newbie)
The fact that only 2 wires are connected is quite correct as you have a mono (not stereo) cartridge. The volume and tone control issues might mean they just need cleaning with a spray contract cleaner like Servisol. Which Fidelity record player is it - an HF42 or an HF45? They are quite different.
Edward. |
1st May 2018, 10:02 pm | #3 |
It is a HF45 but I believe the PCB has HF42 on it. Where do I get servisol from and where do I spray it into or onto please?
Thanks for your help |
1st May 2018, 11:02 pm | #4 |
Well done for getting this far, but WD40 is not good for mechanisms. It's primarily a moisture repellent, and will soon dry up, and you'll be back where you started, with sticking levers etc. Use a light oil, sewing machine or hair clipper oil is ideal, NOT 3-in-1, though, that also dries out quickly.
1st May 2018, 11:23 pm | #5 |
One source of Servisol
http://cpc.farnell.com/servisol/1000.../dp/SASERVISOL You need to spray a small amount into to the volume and tone controls with the power supply disconnected, only apply power when the solvents have evaporated. After spraying Servisol into the control, rotate the control a few times to clean the parts. Note examine the control carefully so the spray the correct area. If there is a on/off switch on of the controls, avoid getting the spray into the switch portion.
Frank |
2nd May 2018, 10:09 am | #6 |
It soulds like your Fidelity HF45 has been fitted with the amplifier from the much smaller, single play, plastic cased, HF42. These HF42's always played loud for their size so it may sound OK in the much larger wooden cabinet of an HF45.
Edward. |
2nd May 2018, 4:14 pm | #7 |
Ordered the Servisol, let's see if it helps. Thanks
12th May 2018, 7:52 pm | #8 |
It has improved it but it is still has no low end volume. Tone has improved.
12th May 2018, 9:28 pm | #9 |
What do you mean by "no low end volume" - do you mean there is no real bass response or just poor overall volome?
Edward. |
13th May 2018, 6:03 pm | #10 | |
Looking at other comments in this thread it's possible that the amplifier PCB was identical for the HF42 and 45 players as they are pretty "basic" units. Is there any chance of some pictures of the innards of your player? Andrew |
13th May 2018, 7:25 pm | #11 |
They were fitted with the BSR X5M cartridge. The H version would have had too high an output.
Edward. |
