14th Apr 2013, 4:08 pm | #1 |
1956 Ekco BP257 4 valve battery portable radio
Hello again,
I don't usually acquire battery only valve radios but I couldn't resist this Ekco in its red polka dot cabinet. It arrived in reasonably good condition and totally original and inside it is dated September 1956. Before powering it up I thought I'd first change any wax and paper capacitors and clean its volume potentiometer and waveband switch etc. This is a fiddly set to dismantle, undo the four screws on the top and remove the knobs at the sides and the chassis will start to emerge from the cabinet but not far enough to really get at the PCB so the ferrite rod aerial was released from the cabinet (3 screws along the back), then the output transformer unscrewed from the inside of the cabinet and finally the loudspeaker released from the cabinet (4 screws) and the whole lot then comes away from the cabinet. There are only six capacitors to replace on the PCB, which are pictured below ... 3 x 0.01uf 2 x 0.001uf 1 x 1.0uf Critical resistors were checked and all were within spec. and the 8uF electrolytic on the output transformer was still good. The volume potentiometer was cleaned with some Servisol 10 and the waveband switch contacts which were quite badly tarnished carefully cleaned with some Brasso on a cotton bud. The valve sockets and pins were cleaned, the battery leads connected to my 90v + 1.4v Little Gem battery eliminator, the set switched on and away she went, working well. RF alignment was performed, and it was found to be only fractionally out. The cabinet was then thoroughly cleaned. The top moulding, tuning wheel and dial assembly were separated from the PCB (remove 2 screws either side and slacken 2 grub screws on the tuning wheel shaft) and then dismantled for cleaning. Everything was cleaned with Sainsburys upholstery cleaner applied with a soft toothbrush, stubborn specks of paint came away with sellotape and brisk scrubbing. The set was reassembled and the odd chip in the red rexine cover touched in with red acrylic paint. This is a most attractive portable radio and the penultimate battery valve model built by Ekco. It sounds good too and in its polka dot cabinet looks every bit a 1950s portable radio. Howard Last edited by howard; 14th Apr 2013 at 4:13 pm. |
14th Apr 2013, 9:01 pm | #2 |
Re: 1956 Ekco BP257 4 valve battery portable radio
Nice looking set Howard well worth the effort only six components changed after all those years nice clean job . Mick.
14th Apr 2013, 10:13 pm | #3 |
Nice work Howard, that really does look terrific. In fact it's inspired me to dig mine out, which is in a different colour scheme to yours.
I like the sound of the Little Gem battery eliminator. Are these still available? If so, where can they (or any other battery elminator) be obtained? Steve |
14th Apr 2013, 10:45 pm | #4 | |
It's a well built set, even its early PCB is in excellent condition. I spent more time restoring the cabinet than I did overhauling the chassis. Howard |
14th Apr 2013, 11:10 pm | #5 | |
The red polka dot cabinet is particularly attractive I think and it's in excellent condition too. There is a BP257 like yours on RMOrg in a Dutch collection so these sets appear to have been exported. There's another one there too in another Dutch collection in a third livery with the Ekco brand name imprinted in the top moulding. http://www.radiomuseum.org/r/ekco_bp257_bp_257.html This model appears to be a fairly rare as the only examples on the web are those on RMOrg. I bought the Little Gem new some five years ago, but I just searched on Google for it and there's no trace of its supplier now. Maybe someone on the forum knows who builds these ? I guess I really ought to build replica B126 and AD35 batteries for it now. Howard |
15th Apr 2013, 9:02 am | #6 |
Never seen one of these before,the top dial seems to have a much more modern look than the mid 50s
15th Apr 2013, 10:13 am | #7 |
I'm not normally in to valve radios - transistor sets are 'my thing'. But, I really love the look of this set. Nice job Howard!
Cheers Pete |
15th Apr 2013, 2:08 pm | #8 | |
Likewise, but this valve portable I thought was exceptionally nice and I couldn't resist buying it. It wasn't cheap either. Howard |
15th Apr 2013, 9:24 pm | #9 | |
I also here that Richard Booth at Past Times Radio is developing one. - Joe |
16th Apr 2013, 12:44 pm | #10 |
Nice looking set and a good job as ever!
Robert |
16th Apr 2013, 8:40 pm | #11 | |
Howard |
19th Apr 2013, 4:05 pm | #12 |
When I started reading the post I remembered who had my one from me, it was steve . but it goes without saying that howard always manages to turn his radios into excellent examples when finished .
Cheers,Neil. |
19th Apr 2013, 8:39 pm | #13 |
It's a lovely set Neil and I'm very grateful to you for putting it my way.
Howard's restoration has inspired me to have a crack at getting it up and running. Steve |
23rd Apr 2013, 7:55 am | #14 |
Mike |
25th Apr 2013, 7:06 pm | #15 |
Thanks for the posting and the pictures. I now know what radio my parents used when on holiday back in the late 1950s/ early 60s. My uncle eventually built an HT battery eliminator (90 Volts).
