9th Aug 2018, 6:19 pm | #21 |
Re: STC portable microphone mixers (1940's)
Unless you go to the esoteric levels of multiple parallel FETs there probably isn`t a lot of difference in noise level between well designed later valve and discrete transistor preamps, I doubt however that the noise performance of the valves used in these mixers would be that good, there was no requirement at the time, most OB mixers were going to be feeding AM broadcasts with limited bandwidth and relatively high noise levels.
9th Aug 2018, 11:26 pm | #22 |
Spec says sigal to noise ratio is "66db at 72sb gain and reffering to peak output signal of +18db"
Is that bad? Interestingly for noise probably a good thing that it can be run on batteries |
10th Aug 2018, 1:39 am | #23 |
That's not too bad at all. It's comparable with typical MC front ends on the face of it, though I wonder if it would still match up by the time RIAA correction has been applied since this adds a drooping gain with frequency which could mean worse results.
11th Aug 2018, 12:38 am | #24 |
Right as in RIAA attenuates the highs so noise in the lows with be at a worse ratio to signal in the highs?
11th Aug 2018, 11:15 am | #25 |
Yes. I'm speculating that since typical MC specs seem to involve about 70dB gain and about 65dB s/n at 1kHz, the mic preamp with only a flat gain of 72dB will have insufficient gain at high frequencies when the RIAA correction is imposed. In simplistic terms, I think you need about 20dB more initial gain.
This could be nonsense of course without any actual information as to what input signal level the mic preamp was designed for.
11th Aug 2018, 1:51 pm | #26 |
Interesting. Well the maximum gain the unit is capable of is 92db. The s/n rating is at 72db but its capable of 92db presumably the s/n is worse at max output.
11th Aug 2018, 1:57 pm | #27 |
4Just wanted to also share this attenuator that I got with the mixers. Presumably also 40's. It has the most impressive pot attenuator inside. Housed in a wooden box lined with copper sheeting inside. Still works great too, dead silent.
11th Aug 2018, 7:03 pm | #28 |
Yes, that's a stud fader. Can be wired with simple potentiometer networks with stud tappings or more usually with multiple tracks of studs with proper Pi or T section attenuators with the studs switching both input and output to the chosen section.
I rewired one as a potentiometer with a special law to work as a feedback element of an active volume control in my homebrew preamp. The snag is getting stereo paths to step at the same time without having to fit mechanical detents. otherwise my balance wanders a little side-to-side. David
13th Aug 2018, 8:53 pm | #29 | |
