1st Apr 2023, 10:19 pm | #1 |
Valve gone microphonic - my fault?
Been reviving a BC5645 , doing the usual cleaning, oiling, greasing, replacing knackered components.
Also in between all this, powering up and seeing what the result was. I had just replaced the 32uf smoothing caps and noticed the radio had gone microphonic. A few taps later and traced it to the dh77 DDT. Could it be something I've done or just coincidence and the valve needs replacing? FM works fine, AM is a bit insensitive and there is an annoying hum on low volumes. Note, I haven't changed out all the hunts 0.01 and 0.005 etc caps yet. Mark |
1st Apr 2023, 10:41 pm | #2 |
Re: Valve gone microphonic - my fault?
A bit of DC on the control grid due to leaking coupling caps can cause the microphonics.
SeE what it's like when you have done your replacements. |
3rd Apr 2023, 10:19 am | #3 |
OK, will update once checked.
3rd Apr 2023, 11:37 am | #4 |
It's really only a 6AT6 in disguise, so there should be no problem replacing it if necessary.
4th Apr 2023, 7:43 pm | #5 |
Replaced couple of caps and a few way out resistors and the AM and FM working fine.
Still a hum and valve still microphonic, but not as much, and the grid measured -0.6v DC. Zero with valve removed. OK on 6at6. Have eye on one for 8 quid delivered. (Apparently never used ;-) ) |
5th Apr 2023, 9:38 am | #6 |
You should be able to find a good pull from a scrap set easily enough. They don't fail very often. Try asking if anybody has one: https://www.vintage-radio.net/forum/...splay.php?f=28
5th Apr 2023, 10:12 am | #7 |
Ta Paul,
I will probably get around to it after I've given the socket a better clean and tightened up the pins. I found a thread on here where someone describes that cleaning the socket and pins etc fixed the same problem. I suppose that if I put the chassis back in the cabinet and the issue isn't noticeable then I'll leave as is. |
5th Apr 2023, 11:12 am | #8 |
If you're interested I have a used Brimar DH77 that tests about 75% on triode and diodes. I'm unable to test it for microphony, but you can have it for £3 postage. You have a PM. Cheers, Jerry
