Old 31st Mar 2023, 6:16 pm   #1
Restoration73
Restoration73's Avatar
Default TV Parts ID?
I have been given some surplus items but would appreciate confirmation.
It is possible these are Philips from a mono valve chassis ;
1. Line output transformer with fibre glass top panel with connections to
line o/p and boost diode
2. 110 degree scan coils
Thanks for looking
ID:	276150   Click image for larger version
Home, home again - I like to be here when I can
Restoration73 is offline
Old 31st Mar 2023, 6:36 pm   #2
slidertogrid
slidertogrid's Avatar
Default Re: TV Parts ID
Hi The LOPT is from the Pye Hybrid colour chassis PCB timebase panel CT203 /205 Etc The scancoils are GEC mono. Probably the Dual standard chassis 2000 or 1000 maybe the single standard "fineline" May fit all. They are handy spares as often the plastic crumbles on these.
Rich
slidertogrid is offline
Old 31st Mar 2023, 6:56 pm   #3
Restoration73
Many thanks, I wasn't sure but I will check the manual, obviously to be used with a
tripler and focus control. I have a spare GEC d/s chassis so I might make a set !
Old 31st Mar 2023, 9:02 pm   #4
alfatangowhisky
alfatangowhisky's Avatar
Location: Dalbeattie, Dumfries and Galloway, Scotland, UK.
Default Re: TV Parts ID?
Yes, coils are GEC I recognise that connector. But standard Plessey assembly anyhow I think?
alfatangowhisky is offline
Old 31st Mar 2023, 9:20 pm   #5
Philips210
Hello again.
As Rich mentions, the LOPT is from a Pye hybrid colour set with the PCB line timebase/power supply. It would be the 697 chassis. They were a fairly reliable transformer. I never had to replace that many.
The scan coils are possibly from a Philips mono TV. Philips liked to use yellow sleeving in their sets. I think its connector is made by Pressac and was commonly used in Philips sets in the mid 1960s to early 1970s.
Regards,
Symon
Philips210 is offline
Old 31st Mar 2023, 9:22 pm   #6
Restoration73
They used a similar connector on the Style 70 Philips if I remember.
The earlier GEC coils had an embedded ntc thermistor in the field coils to keep the
height constant during warm up. Until it disintegrated that is.
I had to refresh my knowledge on 697 chassis, anyway it's good to have a spare.
