Old 18th Jan 2020, 12:42 pm   #1
jonnybear
jonnybear's Avatar
Default Simple Rotary encoder tester.
I wanted a quick check to find out whether a rotary encoder was working or not. so using a cut down PP9 case a SN74LS04, 7809 5 volt regulator caps leds etc, came up with this unit. could be used for other checks more inputs/outputs can be added if required.
ID:	197315   Click image for larger version
ID:	197316   Click image for larger version
ID:	197317   Click image for larger version
jonnybear is online now
Old 18th Jan 2020, 2:37 pm   #2
bc312
bc312's Avatar
Default Re: Simple Rotary encoder tester.
John - great idea, but the 7809 regulator in the circuit diagram is missing the resistor to regulate the output voltage to 5 volts.
Mike
Leave me alone - I know what I'm doing.
BVWS member, EUG, G-QRP
Radio Bygones/Radiophile
bc312 is online now
Old 18th Jan 2020, 5:31 pm   #3
jonnybear
jonnybear's Avatar
Mike
Thanks Mike for pointing my mistake out,
Senior moment should be a 7805 not 7809 which is a 9 volt regulator.
Old 21st Jan 2020, 11:57 am   #4
So the "resistor" will be 0R!
Herald1360 is offline
Old 21st Jan 2020, 3:36 pm   #5
mhennessy
Alternatively, the 7404 could be replaced with the CMOS 40106. This should be pin-compatible, and will run from 3 to 18V, so no regulator needed. The battery life will be much-increased - the 7805 takes around 5mA quiescent and the 7040 will take around 3mA, whereas with the CMOS part, the only current will be that of the LEDs when on. Probably won't even need a power switch.
Downsides? Having to provide pull-up resistors (perhaps 10 to 100k). Might need to think about static protection - probably worth putting resistors in series with the inputs for that.
Nice use of for an old PP9
mhennessy is offline
Old 21st Jan 2020, 10:42 pm   #6
TonyDuell
Be careful if you do that. Some rotary encoders contain TTL ICs and need a 5V (only) supply. And of course the output of such an encoder will be at 5V TTL levels.
TonyDuell is offline
Old 21st Jan 2020, 11:53 pm   #7
mhennessy
The ones I've seen didn't contain TTL ICs - the electronics was integrated into the IR sensor (e.g. Spectrol 120EN) or Hall sensor (e.g. Alps EM11).
I would be amazed if any such encoder would be damaged by a PP3 via weak (10-100k) pullups. And I'm pretty sure that a TTL or CMOS (e.g. HC) logic IC would be just fine.
Of course, a constructive suggestion might have been the part number of a micropower 5V regulator to get around the ~5mA consumption of the 7805. How about the LP2950, for example? But frankly, I'd stick to my earlier suggestion - it was obvious to me at least that this was for mechanical contacting types only. If the OP had provided a 5V output terminal to power an "active" encoder, then that would have been different.
