Old 5th Sep 2008, 2:47 pm   #1
Brian4radio
Brian4radio's Avatar
Default Ever Ready 5008 AC/DC
Hi team, I am refurbing an Eveready 5008 AC/DC set circa 1935.
The valve line up on the cct diagram is as follows TP2620, VP1321 and a PENDD 4020. Fitted in the set instead of the VP1321 is a VP13B, I can't find any info on the VP13B, is it a straight swap or are there a few component changes to make it work. At the moment I have garbled speach on strong stations and very poor sensitivity/selectivity on medium band. regards Brian.
Brian4radio is offline
Old 5th Sep 2008, 3:13 pm   #2
petervk2mlg
petervk2mlg's Avatar
Default Re: Eveready 5008 AC/DC
My Brahns Vademecum indicates that while the 2 valves are similar, they have different bases.
The VP1321 has an anode on the top cap, while the VP13B has the grid on top.
Peter
petervk2mlg is offline
Old 5th Sep 2008, 10:53 pm   #3
Brian4radio
Hi Peter, thanks for that info. I will have to check the wiring around the Vp1321 valve. I must say that the set is working after a fashion so the wiring must have been changed to suit the rogue valve in the past. I will investigate further. regards Brian.
Old 8th Sep 2008, 9:30 am   #4
Brian4radio
Hi Team, I have checked the wiring around the VP13B valve and sure enough as Peter suggested the anode connection and grid connection have been swapped over in the distant past. This leaves me with the original fault. The set only partially works, with only whistles on the medium band and garbled speech on the long wave(radio 4). I have not disturbed the I/F stages, should I alter any of the component values around the VP13B valve to make it more compatable. Regards Brian.
Old 8th Sep 2008, 7:45 pm   #5
Pete_kaye
Pete_kaye's Avatar
Any chance of some photos? I have an Ever Ready mains set from about 1936.It is 'trf' ac/dc and uses some of the same valves as yours.I have never been able to find a circuit for it.There is a Superhet in a similar wooden case ,known as the 5010-what is yours?
Pete_kaye is offline
Old 8th Sep 2008, 8:15 pm   #6
ukcol
ukcol's Avatar
Hi Peter,
Just a thought - If the valve substitution was an unofficial modification, the change in layout may have made the set prone to instabilty. It may be worth trying to get a VP1321 and putting the set back to its original state.
ukcol is offline
Old 8th Sep 2008, 8:50 pm   #7
Brian4radio
Hi Pete, I think Eveready only made a few AC/DC prewar sets i.e. 5008, 5013 (VP13C, HL13C, PEN36Cand a UR1C), 5017 (SIMILAR LINE UP)and a 5221(TH30C, VP13C, 2D13C, PEN36C and a UR1C) . I would think you would get a diagram from the moderator if one fits your set. As for photos I havn't snapped the innards yet but I can if you think it would help in your set identification. regards Brian.
Old 8th Sep 2008, 8:58 pm   #8
Brian4radio
hi Colin, I can obtain a VP1322 which is the same config. as the VP1321 except the base is a Mazda Octal type instead of a B7 base. I havn't found a source for the correct VP1321 valve yet. I would expect it may be quite hard to find a specimen as they were only used in a few sets anyway and it may cost more than the set is worth. Do you know of a "cheap" place I can try? Regards Brian.
Old 8th Sep 2008, 10:25 pm   #9
PJL
Default Re: Ever Ready 5008 AC/DC
Check the metallising is connected properly. Is the TC grid connection screened? Have you changed the caps?
Have you checked the sensitivity control? I am sure it can be made to work...Peter
PJL is offline
Old 9th Sep 2008, 3:44 pm   #10
Pete_kaye
Pete_kaye's Avatar
Mine must be a 5013 then ,as it uses the same 4 valves mentioned.Some are equivalents though(U4020,C70D,VP13C,HL13C).Yes I would like to see photos.I had a thread last year on this topic.
Old 9th Sep 2008, 8:16 pm   #11
Brian4radio
Hi Peter, the T/C is screened and two of the valves have intact metal screening but the PENDD 4020 is not screened and sits quite close to the heater volt dropper which gets quite warm.All the caps have been changed together with the metal rectifier, all three pots and quite a few resistors. These have all been changed to match the cct. diagram. The sensitivity control is set to about 200 ohms and the input voltage is held at 220 volts via variac to avoid the set going haywire. Regards Brian.
Old 9th Sep 2008, 8:19 pm   #12
Brian4radio
Hi Pete, I have snapped the chassis of my Eveready 5008 set . If you send me an email I'll send you the photos . regards Brian
Old 10th Sep 2008, 7:34 pm   #13
PJL
The added dimension is it may possibly never have worked after the valve change and I can't find specs for the VP13B. On the bright side it is just an IF amp...
Check the cathode volts of the VP13B with the sensitivity at max. My calculations say it should be around 1V. Check the voltages on the other valves too.
This set has a horrible arrrangement of switches to use the oscillator triode as a PU amp. Hvae you cleaned the switch properly?
PJL is offline
Old 10th Sep 2008, 9:11 pm   #14
Brian4radio
Hi Peter, I will test the cathode voltages on the valves. The switch is quite robust on this set but I have cleaned the fingers and tested for continuity as a precaution. I did test the VP13B on my valve tester as if it was a VP13A and it seemed to work OK.
My next move on this radio is to get a set of known good valves including a VP1321 and start again.
You may see a success story pop up in the posts one of these days if we are all lucky, watch this space. Thanks again for all your help with this set, kind regards Brian.
Old 10th Sep 2008, 11:39 pm   #15
petervk2mlg
Specs for VP13B:
Vf:13V
If: 0.2A
Va: 200V
Ia 6mA
-Vg1:1V
Vg2:200V
Ig2:2mA
S:4mA/V
Ri:800Kohms
Different base from a VP13A
VP13B base pictured below
Old 11th Sep 2008, 12:04 am   #16
petervk2mlg
It might be worth checking the IF alignment.
This set uses quite a low IF of 127 KHz.
Also what result do you get if you feed an audio signal into the volume control? Perhaps the audio distortion is comeing from the PEN/DD/4020
Peter
Old 12th Sep 2008, 7:53 pm   #17
Brian4radio
Hi team,I have swapped the VP13B for a VP1322, leaving the anode and grid connections as I found them. The set is now working quite well. If I just substitute the PENDD4020 she works for a couple of minutes and then starts to fade so I've swapped both valves. thanks again for all your help and interest. Kind regards Brian.
