9th Oct 2012, 12:02 pm | #1 |
Indicator 6a unit restoration
Well after two years work this is my fully restored indicator 6A unit, part of the Rebecca / Eureka homing and approach aid as fitted and used by the RAF in World War II.
It was in a very sorry state when I found it on Ebay, in July 2010. Apart from being a very rusty chassis most of the original components had been removed. After lots of searching I gradually found replacement parts and re-built the chassis as I found them. This piecemeal assembly, and the fact that I only had a wiring diagram to work from, explains the rather rats-nest look of the wiring. Does it work? Now there’s a question. It works in so far as, the valve heaters light up and the set gets warm. I have not attempted to build an HT power supply for the CRT, as this unit is only part of the Rebecca / Eureka system and as such would not work on its own anyway. As such I though it was not worthwhile to introduce the 1800 volts it needs just for the sake of it. |
9th Oct 2012, 12:08 pm | #2 |
Re: Indicator 6a unit restoration
More pictures.
9th Oct 2012, 2:02 pm | #3 |
Well done, Mike, it looks good!
Amdy |
9th Oct 2012, 8:59 pm | #4 |
Great job Mike, you might find this site of interest.
http://website.lineone.net/~norman.groom/ There is a description of the ASV showing a working 6a (scroll down on the home page). Peter |
9th Oct 2012, 9:30 pm | #5 |
Even better is this film showing its use in the Rebecca system in a Halifax
http://film.iwmcollections.org.uk/re...7&media_id=269 Andy |
10th Oct 2012, 2:40 pm | #6 |
Very Impressive.
