15th Jun 2018, 10:28 pm | #1 |
Ekco 9 Octave
Hello everyone.
I've been working on my Ekco 9 Octave but have hit a snag. A stupid amiter one probably. But I have found Some Hunts Mouldseal capacitors on the input matching switch that have 220 printed on them Is this 220uf ? They are the extremely small brown hunts caps. Thanks for your help. |
15th Jun 2018, 10:37 pm | #2 |
Re: Ekco 9 Octave
If this is a RP341 the manual is here, perhaps the easiest way to find its value.
https://www.service-data.com/product...93/2142/m11493 It’s a long time since I fixed them but they were good players.
Frank |
15th Jun 2018, 10:42 pm | #3 |
Re: Ekco 9 Octave
There's some 220pF's in the schematic, it might be them, definitely not 220uF.
Lawrence. |
15th Jun 2018, 10:44 pm | #4 |
Re: Ekco 9 Octave
That's why I was confused 220uf seemed a miss but I wanted to be sure.
15th Jun 2018, 10:46 pm | #5 |
Re: Ekco 9 Octave
A small mouldseal cap would not be 220uF.
C1, C8, & C20 are 220pF. crossed with Lawrence Mike |
15th Jun 2018, 10:55 pm | #6 |
Re: Ekco 9 Octave
Does it have the stereo unit as well E-Scott?
Dave |
15th Jun 2018, 10:58 pm | #7 |
Re: Ekco 9 Octave
No unfortunately not I only have the main record player unit.
S |
15th Jun 2018, 11:23 pm | #8 |
Re: Ekco 9 Octave
Hi Dave,
I found a post from 2008 that a Dave Walsh had or still has both units, is that you? https://www.vintage-radio.net/forum/...ad.php?t=29338
Frank |
15th Jun 2018, 11:29 pm | #9 |
Re: Ekco 9 Octave
Ok thanks for that Scott. I have seen the occasional SU offered but I was fortunate enough to get both from a Forum Member a few years back. I've never seen the two offered together anywhere else though They are quite a high quality build and well spoken off. I've tried to find out how many were actually sold in the past. There should be a few threads if you search on here!
PS. Yes that's me Frank. Despite what the OP said, I had to learn the hard way, I fired up the main unit and got a very muffled sound before realising that [a] it need to be on its legs and [b] you had to open the baffle ports underneath [he said laughing]. If anyone has any literature or other info re these [apparently rare ] items please let me know? You can see from that thread I was in Rammy and Bexhill as usual. If I hadn't had relatives in Bicester who could collect, I wouldn't have got involved. Serendipity I suppose but as Scott will know, these are fairly heavy and not really so portable! Dave Last edited by dave walsh; 15th Jun 2018 at 11:52 pm. |
16th Jun 2018, 7:04 am | #10 |
Re: Ekco 9 Octave
Those 220PF caps are unlikely to need replacing.
16th Jun 2018, 7:49 am | #11 |
Re: Ekco 9 Octave
Ok Dave, I had forgotten about the baffle port myself. The last time I saw these was in the 1960’s and not many then. We were the Ekco agent in Wigan so sold perhaps two or three, they were expensive, I don’t think they would have made many of them.
I do remember they sounded good though.
Frank |
16th Jun 2018, 10:51 am | #12 |
Re: Ekco 9 Octave
16th Jun 2018, 1:55 pm | #13 |
Re: Ekco 9 Octave
Unfortunately they are all in about the same Shape. Crumbling to pieces. And at any rate they are always leaky.
The thing dose indeed weigh a ton. I have had this machine since I was 17 and played about with it then it sounded great back then though on its original caps etc. But after a while of use on those caps it started to audibly distort. By that point I was 20 odd and I had been running it on the original caps. I had to much to do at the time (mostly studying) so so unfortunately I couldn't devote the time to restore it. With that it ended up in the storage cupboard up stairs till now. At the time I was reluctant too replace parts when it was working so well. If it wasn't for the fact that after those years of use it started to fail I would have probably continued using it. It's extremely well made and appears indeed to have been an expensive machine. There is not a single wax cap in the thing. They are all the large Mouldseal caps or aluminium visconal type caps. I wouldn't even hazard a guess to the price! Ekco really didn't cut corners when it came to build quality. S |
