Old 30th May 2022, 3:02 pm   #1
AdrianH
AdrianH's Avatar
Default A question going back to some 1920s wireless circuits
I like to read and will often print off old articles, I downloaded and printed off a Popular Wireless Valve Experimenters handbook.
But on reading the text and looking at the circuits I am greatly confused with circuits that are shown as 2 Ohm grid leak resistors. Now I am guessing that they should be 2 M Ohm (2,000,000) but suspect the M was typically dropped as it is not just one drawing but many?
ID:	258052Click image for larger version
ID:	258053Click image for larger version
Also seen in Wireless constructor of the same era.
So please tell me that I am correct in the assumption that these are Million Ohms and not 2 or fraction of Ohms?
Adrian
Asking questions and learning, or trying to!
Youtube EF91Valve
AdrianH is online now
Old 30th May 2022, 3:18 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: A question going back to some 1920s wireless circuits
I think you will find that the Ω was used in may 1920's circuits to mean MegaOhm.
Cossor were using this in some documents even in the 1930's
For Ohms they used used ω which is the lower case version of Omega
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 30th May 2022, 3:24 pm   #3
The different terminologies can be deeply confusing; I've got a genuine RCA schematic for my AR88 receiver where they use "M" to signify Kilohms, and "Meg" for Megohms.
[I can only think that the use of M for Kilohms is because M is what the Romans used to signify 1000]
Old 30th May 2022, 3:31 pm   #4
AdrianH
AdrianH's Avatar
It is confusing when they can talk of 300 to 400 Ohm potentiometers in part of the circuit and then use 2 for 2,000,000 Ohms etc ( I am not sure how to use the symbol ). It sort of stops me in my tracks.
Adrian
Youtube EF91Valve
Old 30th May 2022, 6:42 pm   #5
Junk Box Nick
Junk Box Nick's Avatar
In my 1924 Boy’s Book of Wirelesss the Ω symbol doesn’t make an appearance; values are denoted using either ‘ohms’ and ‘megohms’.
In my 1930s Cassell’s book, rheostat values are followed by ‘ohms’. There is no value shown for a grid leak though they do show you dimensions for making one out of a length of pencil.
In my 1932 Everyman’s Wireless there are values such as 50 000 Ω and values of 1mΩ and .5mΩ (using a lower case ‘m’) so Ω would now appear to be as we understand it.
k for kilo doesn’t seem to have arrived at this point
Thus in your books as they write 300 ohms when notating potentiometers the convention would seem Ω for a megohm and ohms for smaller values.
Junk Box Nick is offline
Old 30th May 2022, 7:13 pm   #6
AdrianH
AdrianH's Avatar
I have a pdf of 'The Boys Wireless Annual 1925' and as you say no mention of Ω.
I am just used to the modern convention of
p for 1/1000,000,000,000
n for nano 1/1000,000,000
μ for 1/1000,000
m for milli 1/1000
etc. that this old convention threw me.
Adrian
Youtube EF91Valve
Old 30th May 2022, 10:25 pm   #7
Junk Box Nick
I remember n for nano turning up. The first time I saw nF I couldn’t figure out what was going on. I forget who told me the answer – probably the science teacher. No Google in those days!
In Practical Wireless and the usual books of the time I had been used to just pF and μF; and μF was sometimes mfd on some (new) components.
I had seen kpF on some circuit diagrams which was distinctly odd.
Old 31st May 2022, 2:23 pm   #8
Dave757
I don't understand why the HT- in Adrian's first circuit is taken to the
LT+ rather than to ground.
Re the AR88 Schematic use of M for Kilo I remember having some
AR88 potentiometers which were marked in this way.
Kind regards
Dave
Dave757 is offline
Old 31st May 2022, 4:48 pm   #9
Cobaltblue
Cobaltblue's Avatar
I would expect that it would effectively make the grid slightly negative with respect to the HT -ve (about halt the filament supply) if it were connected to the other way around the grids would be slightly positive.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 31st May 2022, 5:38 pm   #10
kalee20
I've seen ω for ohms, but I hadn't made the connection that Ω could be megohms in the terminology.
LTSpice uses M and m for milli (it's not case sensitive) and Meg or meg for mega.
Originally Posted by Dave757 View Post
You generally get better results when the grid leak is returned to filament +ve rather than filament -ve.
So what they've done is exactly that, and they went the whole hog and made filament +ve the ground line. And then they've taken HT -ve to ground (which is conventional!).
kalee20 is offline
Old 31st May 2022, 9:41 pm   #11
Dave757
Hi Mike,
Many thanks for explanation, - point taken!
Kind regards
Dave
Dave757 is offline
Old 31st May 2022, 9:54 pm   #12
AdrianH
AdrianH's Avatar
https://worldradiohistory.com/UK/Pra...20Handbook.pdf is the download link at the moment for the one I am reading
Later images do show both HT- and LT- being common and ground, sometimes using a potentiometer to shift the grid leak potential between 0 and +2 Volts as in this image: -
At the end of half term break when the Mrs goes back to work, i hope to be playing with 2 Volt battery valves.
Adrian
Youtube EF91Valve
Old 10th Jun 2022, 12:40 pm   #13
AdrianH
AdrianH's Avatar
Have been playing this week and have built a one valve receiver using regen or reactive feedback, which ever you call it.
Quite surprised with how well it works to be honest.
Next step is to add a LF valve and try and come up with a suitable high impedance speaker! and the odd LF transformer.
Adrian
Youtube EF91Valve
Old 10th Jun 2022, 5:32 pm   #14
That wiring should be 1/16" square section with neatly dressed right angle bends!
Whatever is a "star" point doing in a '20s reproduction?
Nice job, really!
Herald1360 is offline
Old 11th Jun 2022, 10:17 am   #15
Junk Box Nick
These little sets are great fun and can work very well.
I have rebuilt my HAC one valve kit I had as a boy in the mid 1960s. I still recall the magic of trawling the shortwave bands and hearing amateurs for the first time. Sadly, the broadcast bands are nothing like as busy as back then.
Old 11th Jun 2022, 4:07 pm   #16
AdrianH
AdrianH's Avatar
Nice job, really!
It's not a star point, just three wires crossing at different heights, awaiting some better coils to get made.
Adrian
Youtube EF91Valve
