Old 20th Jul 2018, 3:57 pm   #1
Skintin
Default Fuse Required for jukebox
Hi Guys,
im after the following fuse for my jukebox. anyone know a site where i am able to get one.
The fuse is a :
30 V.A.C. 6 1/4 A MDL.
Any suggestions would be much appreciated
thanks
tom
Skintin is offline
Old 20th Jul 2018, 7:22 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Fuse Required for jukebox
Sounds like a standard 1.25" Bussmann fuse type.
https://uk.rs-online.com/web/p/cartridge-fuses/8527168/
Sounds about right. If not, RS do other values in the range. (Not clear whether you need 6A, 0.25A or 6.25A.)
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 20th Jul 2018, 7:36 pm   #3
Skintin
Yeh with it being 6 1/4 i take it that the metric would be 6.25A
just done a little bit of digging too and some suggest that the voltage is 250vac not 30vac then put in a 6A not 6.25A.
Is this ok or should i just stick with the 6.25A
cheers
tom
Skintin is offline
Old 20th Jul 2018, 7:43 pm   #4
sortedradio
sortedradio's Avatar
A voltage rating higher than 30V is fine, and I would think 6A will be ok, unless of course there is a fault which caused the original fuse to blow!
Martin
BVWS member
GQRP Club
sortedradio is online now
Old 20th Jul 2018, 7:52 pm   #5
Skintin
no there was no fault. i had just bought a NOS push bar assembly and was testing it but unfortunately a little strand of cable had straddled the + and -.
obviously, the fuse popped as a protection.
just hard to find the manufactures ideal fuses now. so was looking for a replacement or near enough. However, i noticed these are out of stock at rstrade.......nought new there then.
cheers for the advice
tom
Skintin is offline
Old 20th Jul 2018, 9:14 pm   #6
buggies
buggies's Avatar
You could try Farnell or CPC for 6.3 Amp fuses.
George
buggies is offline
Old 21st Jul 2018, 9:53 am   #7
Herald1360
Herald1360's Avatar
Pretty much any inch and a quarter 6A or thereabouts time delay (slo-blo) fuse will do for this.
The Bussmann MDA ceramic series would be an upgrade possibilty and may be more available. At any rate, RS have stock.
....__________
