26th Nov 2015, 10:41 am | #1 |
Bush TR82 battery
Probably the most extreme case of battery corrosion I have ever seen. To make matters even worse, two more were stored in there rather than being disposed of.
Neil
26th Nov 2015, 10:50 am | #2 |
Re: Bush TR82 battery
Guinness book of records? Probably the worst I have seen but the chassis looks in good condition in spite of it.
Peter |
26th Nov 2015, 10:58 am | #3 |
I've seen similar on some Ray-O-Vac SP11 cells which dated from about 1960. Beneath the corrosion, you could just manage to read the word... "LEAKPROOF"
26th Nov 2015, 11:26 am | #4 |
I see that yours has lost a push button rod from the wavechange switch. Mine was the same with corrosion and damp rusting the switch mechanism away.
I also had rust and rot a third of the way up the case as the radio had been stood in water for a long time. With a new speaker fitted, it worked! Those batteries are probably leak proof now that they are empty. Still good sets these old Bush. |
26th Nov 2015, 4:12 pm | #5 |
Yes Sam, I was able to repair the original plastic push rod coupler with hot melt glue. It only has to work in compression so is amply strong.
Neil
26th Nov 2015, 5:05 pm | #6 |
A matched pair! Must be worth more than two singles.
Yes the problem is general fumes from decomposing batteries causing O/C output transformers, IF coils, rotted valve holders and low Q frame aerials. The TR82 is a tough boy and should be workable. John. |
26th Nov 2015, 5:27 pm | #7 |
Watch out for rotted transistor wires which are common when these have been badly stored. It's an easy job to replace any bad ones though.
