Old 4th Dec 2010, 11:53 am   #1
M0FYA Andy
Default Welwyn Panclimatic Resistors
Has anyone got any information on the Welwyn series of "Panclimatic" resistors, ideally a Welwyn datasheet or catalogue?
They are usually seen in test equipment, but as I have quite a lot I'm wondering about using them for more general applications.
They come in a range of physical sizes, it would be useful to know the power and voltage rating of each size.
On some it is possible to see a spiral under the black paint - are they a carbon film type of construction?
Thanks for any help,
Andy
M0FYA Andy is offline
Old 4th Dec 2010, 12:59 pm   #2
ronbryan
Default Re: Welwyn Panclimatic Resistors
Andy
The High Stability Panclimatic Protected (to DEF-5112) C20 series are:-
Type, Rating at 70C, Limiting Voltage.
C20 0.125W, 200V
C21 0.25W, 250V
C22 0.5W, 350V
C23 0.75W, 500V
C24 1.0W, 800V
C25 2.0W, 1500V
C13 1.0W, 800V
C14 2.0W, 1600V
All are humitity class H6
The resistive element is a pyrolitic carbon film deposited on to a high ceramic rod. The desired resistance is obtained by cutting a helical groove through the film.
Welwyn Electric Catalogue 1970-71, pages 40 and 41
Ron
ronbryan is online now
Old 4th Dec 2010, 2:32 pm   #3
M0FYA Andy
Ron,
Thanks for that, some very useful information.
Has anyone got experience of using this type for general use? I imagine they are a bit inductive for RF use, but should be fine for audio?
Andy
Old 7th Dec 2010, 12:14 am   #4
Graeme Murphy
No experience of using/making them but I do work for said employer !
I can remember these being made when I started work way back in the late 1970's. A rather expensive component if I remember rightly.
Graeme Murphy is offline
Old 9th Dec 2010, 12:05 am   #5
glowinganode
glowinganode's Avatar
Here are some from stock, the second one down is a C22. None of the others are marked, but I can probably work out which is which.
Also a Salmon pink version and a Painton device both of identical size (and power dissipation I assume) the the one above.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing.
glowinganode is offline
Old 9th Dec 2010, 8:37 am   #6
M0FYA Andy
Does the black or salmon pink paint imply a different range with different characteristics? I usually associate pink resistors with high stability types, but I assume the black ones are also high stability as they were used extensively in test equipment.
Andy
Old 13th Apr 2011, 12:43 pm   #7
Graeme Murphy
Catalogue found !
I will post the data tonight.
Old 13th Apr 2011, 11:21 pm   #8
Graeme Murphy
As promised, this data is reproduced from the product catalogue of Welwyn Electric Limited 1968-1969.
Name:	Page 32 top.jpg
ID:	49511   Click image for larger version
Name:	Page 32 bottom.jpg
ID:	49512   Click image for larger version
Name:	Page 33 top.jpg
ID:	49513   Click image for larger version
Name:	Page 33 bottom.jpg
Old 14th Apr 2011, 7:11 am   #9
M0FYA Andy
Very useful data!
Many thanks,
Andy
