21st Jun 2020, 9:11 am | #1 |
Kenwood TS-830S ALC
hi,
problem with alc in ssb, not enough output, drive is ok, cw output ok need to turn te mike gain pot fully cw for meter deflection and output carlos |
21st Jun 2020, 11:38 am | #2 |
Re: Kenwood TS-830S ALC
What happens when you transmit CW?
Have you joined the Kenwood Hybrids .io discussion forum? They can fix anything and everything! Peter - G3PIJ |
21st Jun 2020, 12:32 pm | #3 |
Re: ts830s alc
good day to you,thanks reply
in cw i have full output, no problem there with the mike gain fully cw, thus max gain i need a firm wisthle to obtain full output, mike gain at 10 o clock gives a 10 watts output with a firm wisthle, not responding to voice like its should be. seems there is something in te circuit thats attenuating the mike signal carlos |
21st Jun 2020, 12:34 pm | #4 |
Is the mic itself ok I wonder?I have had one Trio mic fail last year.
21st Jun 2020, 12:59 pm | #5 |
Does operating the PROC switch a few times have any effect?
21st Jun 2020, 1:15 pm | #6 |
hi, mike is ok, tested on another ts830
activating processor switch give me full voice ouput 100w deactivated almost nothing in voice, ferm wistle i get 100w, in voice almost no defection carlos |
21st Jun 2020, 1:43 pm | #7 |
hi, solved, oxidized processor switch, deoxit has done the job,
full output now in voice, very sensitive now. thanks to all and martin who came with the golden tip about the processor switch. carlos on6cn |
