3rd Jul 2019, 4:50 pm | #21 |
Re: Vintage car radio to amp
I was lucky as the Rover has a lot of space behind the dashboard so I could build a box in which to fit the radio. The idea of using an ice cream tub or similar to see whether there was any improvement came to me because I once removed the speakers from a scrapped electric organ and those that didn't have much baffle were enclosed in a sort of pudding bowl, presumably to act as a sort of infinite baffle.
The combination of a better speaker and some sort of enclosure may well help. As you say, the engine noise in these old cars is rather a hindrance. We forget how quiet modern cars are inside in comparison.
Paul |
3rd Jul 2019, 6:20 pm | #22 |
It seems to me that the correct manual for your Hildesheim, at least according to the picture of the radio, is this one:
https://nvhrbiblio.nl/schema/Blaupunkt_7639000.pdf Unfortunately not made by the factory for use with external amplifier. It does, however sport a reasonably powerfull amplifier section itself using complementary Germanium output transistors AD161/AD162. They will usually provide about 4~6 Watt output with a 12V supply voltage, more than enough if connected with a quality speaker in a suitable enclosure. A suitable enclosure is not an open baffle as the one shown. Bass will be next to none existent imho. You could do an experiment and connect the radio to a small hifi-speaker in a closed or bass-reflex cabinet. That should give you an idea about what the radio is capable of. If you find it to be OK, and even though AM stations are nowhere near the quality of FM and DAB, the sound is original and vintage to go with the car. Next will then be to replicate that sound quality into the baffle setup. Not an easy project! Rgds, /Torben |
4th Jul 2019, 3:23 pm | #23 | |
4th Jul 2019, 4:30 pm | #24 | |
4th Jul 2019, 4:39 pm | #25 | |
