Old 29th Oct 2020, 9:14 am   #1
kestrelmusic
kestrelmusic's Avatar
Default Smoker's Cabinet set
My latest restoration is a late 1920s 'Smoker's Cabinet' set. It is based around a British General coil pack. I had some fun with this as, although all the windings showed continuity, I had to re-wire the reaction coil, as the leads pass through a metal tube and the insulation had crumbled to dust!
I had to more or less guess the circuit, as it was in pieces when I got it, and two of the capacitors had to have the pitch melted out and a modern component inserted. But here it is, more or less finished, and working well.
The coil pack is a curious thing, with two sets of tappings, one from the top for the aerial and one from the bottom for range. The reaction coil is movable, controlled by the knob. I have found that in use the reaction control is very sensitive - no more than a degree or two separates silence from oscillation! But it picks up strong stations well. And it's a handsome piece of furniture. Now, where can I put it?...
ID:	219143   Click image for larger version
ID:	219144   Click image for larger version
ID:	219145   Click image for larger version
ID:	219146   Click image for larger version
kestrelmusic is offline   Reply With Quote
Old 29th Oct 2020, 9:42 am   #2
vinrads
Default Re: Smoker's Cabinet set
That's looking very nice Gerry, well done restoring it ,I am sure it will find a home somewhere , Mick.
vinrads is offline   Reply With Quote
Old 29th Oct 2020, 9:59 am   #3
Peter.N.
Excellent job - I wish radios were as simple as that now!
Peter
Peter.N. is offline   Reply With Quote
Old 29th Oct 2020, 2:00 pm   #4
Nice looking set, there, but isn't 10nF rather large for the detector grid capacitor? It might have some bearing on your over sensitive reaction problem too.
Old 29th Oct 2020, 6:41 pm   #5
murphyv310
murphyv310's Avatar
Hi.
Agree with Chris. C1 should be around 100pf.
Trevor
Keep safe everyone.
murphyv310 is offline   Reply With Quote
