2nd Jan 2020, 3:53 pm | #41 |
Re: Nude EF50's Look Great
Sylvania is from the USA.
2nd Jan 2020, 4:02 pm | #42 |
Sylvania were a manufacturer of light bulbs and radio valves.
"Sylvan" is an adjective, derived from Latin, and meaning related to woodland. Transylvania literally means a place on the other side of the forest. Sylvanian Families were a range of collectable animal figures, with a matching range of houses, furniture and vehicles to ensure that there was always something else for a parent to buy .....
2nd Jan 2020, 4:49 pm | #43 |
One of my main interests is in WW2 airborne radar, H2S in particular, which of course used VR91/EF50's in quantity. In one of the documents I have there is an observation that Mullard EF50's are causing problems in certain locations in the H2S system, and Sylvania examples should be used instead as their quality is better.
I'll try and find the exact reference. Andy |
2nd Jan 2020, 5:45 pm | #44 |
Sylvania are still very much around - though they've moved on from making EF50s and now do a good line in decently-low-RF-hash-generating GU10 LED 'bulbs'!
2nd Jan 2020, 6:53 pm | #45 |
These classic valves are revealed as very futuristic looking [without the "can"] by Mike in post 1*.
Quite unexpected! As Andy said [post 6*] "nude" tends to engage the brain. It's genetic you know, although conflating that word with "spanking", in the initial post, could be asking for trouble Perhaps it's just me? Dave W Last edited by dave walsh; 2nd Jan 2020 at 7:03 pm. |
2nd Jan 2020, 8:39 pm | #46 |
As a consenting adult, the matter can probably be considered closed in this instance.
2nd Jan 2020, 10:55 pm | #47 | |
The Murphy TA160 of 1951 used this kind of image-reduction circuit, and had 6F1 high-slope pentode RF amplifier. Other British domestic receivers of the period to use high-slope pentode RF amplifiers were the Ambassador Viscount, with the EF80 and the Armstrong EXP119 and BS125 (early version), with the 6F13. I think that there may have been some other late 1940s domestic receivers that used the EF50, perhaps the Ace 600 and Strad 491E, but I am not sure. In its 1950s point-to-point HF communications receivers, Marconi typically used two RF stages, with a Z77 high-slope 1st stage and a W77 remote cutoff 2nd stage. It looks as if it saw the Z77 as the successor to the EF50 for that application. Moxon mentioned the SP41 high-slope pentode, which I think was the 4-volt heater counterpart to the SP61. The latter, of course, was the valve nominated by Baxandall for use in his fairly well-known 1950 (published in 1952) tone control. He commented that a high-slope pentode was required for best results, although other valves could be used for less critical applications, with an EF37A recommended where input signal levels were below about one volt - presumably that spoke to the higher microphony typical of high-slope pentodes. But Baxandall’s use of the SP61 does provide a very credible case for the selective use of high-slope pentodes in AF applications. Cheers, (1) L.A. Moxon; Recent Advances in Radio Receivers; Cambridge University Press; 1949. |
2nd Jan 2020, 11:54 pm | #48 |
It's been suggested that if the city of Cambridge had been closer to London and had enjoyed a better TV signal, the EF50 might never have been developed and Britain's WW2 radar wouldn't have been so successful.
In the late 1930s, Pye of Cambridge were a successful TV manufacturer, but ironically the Alexandra Palace signal barely reached Cambridge: its range for reliable reception was some 25 miles and Cambridge was almost 50 miles distant. C O Stanley, owner of Pye, was determined to market a set of high sensitivity that would give reliable reception of Alexandra Palace in Cambridge. Back in those days, that required a multi-stage TRF tuned to 45Mhz (presumably with excellent screening between valves). Pye engineers specified the EF50 and the Pye valve company, Cathodeon, had a go at making it but failed. Fortunately, Pye also had relationships with Mullard and Philips. Mullard struggled with the innovation in the EF50 and in the end it was Philips in Einhoven who succeeded in manufacturing the valve. So Pye ended up with the most sensitive TV receiver in 1939, just as war broke out and Alexandra Palace ceased to transmit. Timing could have been better. However, that high gain TRF TV receiver chassis turned out to be an ideal IF strip for the all-important radar systems then under development. The technology transfer idea was facilitated by a familiar radio name: Edward Appleton, then of St John's College. So it was that a valve born of the poor TV signal in Cambridge could claim to have helped win WW2. The Eindhoven production was of course short-lived after the Nazi invasion of the Netherlands and, in a series of events worthy of a James Bond movie, the EF50 manufacturing data, tooling and thousands of the unique glass bases were transferred from Holland to the UK to allow manufacture to continue (by Mullard, M-OV & Cossor), and to the USA (Sylvania) and Canada (Rogers). So whether an EF50 is red or silver might just give a clue as to its manufacturer, but then again it might not. Martin
BVWS Member Last edited by Hartley118; 3rd Jan 2020 at 12:03 am. |
3rd Jan 2020, 1:12 pm | #49 |
Sylvania was split up. Philips bought their consumer electronics division and I think their components division (Sylvania ECG anyway) together with the Philco brand name. Their lighting division (or RF-hash-generator division) is part of Osram.
4th Jan 2020, 5:41 pm | #50 |
The BBC used the EF50 in their AMC/3 microphone amplifier.
4th Jan 2020, 8:10 pm | #51 |
Interesting place to find a valve considered to be somewhat microphonic. I wonder if they had anti-vibration mountings?
The rest of the circuit used CV138 (EF91) throughout, so the EF50 was in there for a special reason. I wonder if it happens to have better than average noise behaviour for a pentode at the particular source impedance it is presented with? Shunt feedback as well. David
4th Jan 2020, 10:53 pm | #52 |
In the description of the potable acoustic measuring unit is included the comment:
“At the time when the amplifier was designed, miniature valves having a sufficiently low level of hum and microphony for first stage operation were not available. As a compromise, however, selected specimens of the EF50 are used.” From that one could reasonably infer that the better EF50 samples (along the desired low-hum, low-microphony vector) were better than the better EF91 (CV138) samples. One could wonder why not the EF40, which was in the initial Rimlock range and so might have been available when the unit was designed, although Mullard may have been slow to start UK production of some of the early Rimlocks, perhaps concentrating on the core radio types. Later in the description it was noted that the input transformer and valve, etc, were on a rubber-mounted sub-chassis. There is more detail about rubber mounting and its isolation benefits in the description of the AMC/3. Cheers, |
4th Jan 2020, 11:45 pm | #53 |
No Longer a Member
Interesting to note from the text though (attached), the EF50 was thought to be a compromise for the application. And that they had to hunt through some to find the better ones.
5th Jan 2020, 9:02 am | #54 |
I think the EF40 was not available at the time but the EF37A was and given that an EF50 is not exactly miniature you might think it woud have been a more obvious choice.
The microphony problem was probably not serious since the unit would be in an equipment rack some way from loudspeakers or other dissruptive noise. |
5th Jan 2020, 5:38 pm | #55 |
By coincidence I have been browsing some old radio books and found the 'all EF50 TRF' article in the July 1947 Short Wave Mag. by G5UM It's on the US history of radio site as well. there is also a follow-up article in the August issue about neon stabilisers. I might have a go at this as I have the inevitable big box of these bottles under the bench, plus plenty of other bits as well.
I should be able to fit it onto a mess tin as a chassis. Mike, G3ZII.
HAPPINESS IS A WARM WIRELESS PREVIOUS USER NAME- MIKE G3ZII |
