1st Mar 2016, 1:48 am | #1 |
Pye Black Box resistors.
I'm having trouble understanding 2 resistors, I have the data sheet etc. The 2 I'm stuck on are
R8 2.2m ohms, only one I can find is rated 1 watt 10000v is this correct. The other one which is the same on 2 parts of the circuit are R9 and R11 I think they're showing as 57k but with what looks like a crucifix in front of them. This one I'm completely at a loss with. I'm replacing all components onboard for new ones, and have managed on all other ones but these 2 have me stumped. Any help greatly appreciated. |
1st Mar 2016, 2:34 am | #2 |
Re: Pye black box resistors.
You appear to be using the Trader sheet. If you look at the bottom of the components list it explains that the value of R9 and 11 can be between 47 and 68k and are high stability. These days all resistors are more or less HS. Replace them with the same value you find fitted in yours. One watt resistors are a good physical size for old equipment, the others can be a bit small.
1st Mar 2016, 8:45 am | #3 |
Thank you for that information. I've gone for 2W resistors as recommended by someone on forum. The issue with R9 and R11 is I couldnt find a resistor available that was 47k on the market. So was not sure which one to replace it with.
1st Mar 2016, 9:33 am | #4 |
Unbelievable. 47k is a frequently used preferred value and easily obtainable.
1st Mar 2016, 9:41 am | #5 |
Also the 2.2 resistor the only one I could find was 1w which I'm guessing should be fine. All others being replaced are 2w
1st Mar 2016, 9:45 am | #6 |
You can replace any resistor with a higher power one, but it may be more expensive or cosmetically unacceptable compared with a resistor of the correct power rating. Modern resistors are physically smaller for the same power rating.
1st Mar 2016, 10:01 am | #7 |
Both the 47k ones are reading 57.5k and 58.5
1st Mar 2016, 10:34 am | #8 |
Replace them with whatever the colour code says. Presumably 47k, Yellow, Violet, Orange?
1st Mar 2016, 10:38 am | #9 |
Might I recommend the following resistor:
47k 2W at Cricklewood Electronics Replacing resistors popular these days but is rarely necessary. In a typical record player or radio, there are a few circuit positions where it is good to have a decent accurate resistor and if it has drfited badly, replacement will improve performance. For true HiFi there might also be a small improvment in linearity and noise by upgrading certain old carbon comps to metal film. But as for replacing every resistor, many of them will work fine if they are within +/- 50% or more, and no benefit at all is gained by wholesale replacement. |
1st Mar 2016, 11:03 am | #10 |
They're showing green violet orange orange. Just checking as unsure if these are original or have been replaced with incorrect ones
I'm thinking more reliability rather than performance enhancement The crickewood one you link is showing Diff bands |
1st Mar 2016, 11:10 am | #11 |
It's just an example of what a resistor looks like. They won't go to the trouble of photographing every resistor they stock.
Only change one component at a time, so if you make a mistake you'll know where it was.
1st Mar 2016, 11:19 am | #12 |
I'm confused , the service sheet is saying 47k but the 2 that are in read 57.5 and 58.5 so do I put in 47k as per service sheet or 57k which is closer to the ones that are in?
1st Mar 2016, 11:36 am | #13 | |
As Bill says, "If you look at the bottom of the components list it explains that the value of R9 and 11 can be between 47 and 68k and are high stability." So replace with the closest to what is in there at present. Colin |
1st Mar 2016, 11:42 am | #14 |
It does not matter much about those values so long as they are equal
nothing wrong with 57.5k and 58.5k they were possibly both 56k and yours are within tolerance Pye just used what they had in stock. |
1st Mar 2016, 12:01 pm | #15 | |
Could they be Green, Blue, Orange 56k? The second orange may in fact be Gold indicating 5% tolerance. They're still in tolerance after 50 or 60 years, so why not leave them alone?
1st Mar 2016, 12:13 pm | #16 |
Re: Pye Black Box resistors.
I'd be rather pleased to find ones that close after so long- whilst it can be wise to weed out badly drifted resistors, it's just making unnecessary work to blanket change things and runs the risk of introducing a fault.
1st Mar 2016, 12:29 pm | #17 | |
If reliability is a concern then 56k close tolerance resistors should be ok. Lawrence. |
1st Mar 2016, 12:35 pm | #18 |
I have the PCL83 version, not sure if this is the same model as the OP
The resistors on mine are 57k ie green, violet, orange.
Howard |
1st Mar 2016, 12:46 pm | #19 |
The resistors are still in tolerance, even though they're 57k. If the OP wants to change them he can use 56k with 1k in series.
1st Mar 2016, 1:48 pm | #20 |
Those resistor values sound reasonably well matched to me. I wouldn't mess with them. Could that second 'orange' band actually be salmon pink - the indicator of a high stability resistor?
Martin
BVWS Member |
