21st Feb 2016, 5:00 pm | #1 |
Identify Output Transformer
Hi folks,
I am hoping to get some information on the operating values of an unknown transformer, see pic attached. It came out of a self-build Mullard 5-10 amp I have measured resistance across all combinations on each side. I would like to know what the primary and secondary winding impedances are but I don’t know how to work this out from the DC resistance or in fact if this is possible. I am hoping the fact it came from a popular vintage amp will help. I also would like to know what the windings look like in relation to the wires. Any pointers would be welcome, Ray |
21st Feb 2016, 10:07 pm | #2 |
Re: Identify Output Transformer
Hi Ray, it looks like one of the many that were produced by various firms for this popular amp. The 2 primary halves have the sec windings wound in the middle of them, hence sec resistances are about equal while primary resistances vary a lot due to the different mean lengths of turns.
Red is HT+, the two yellows are either anodes The sec windings will have been connected in parallel for 4R and series for 16R. If you apply a low voltage 50Hz signal you will be able to work out the turns ratio and phase relationships between the windings. Ed |
21st Feb 2016, 10:34 pm | #3 |
There is also a detailed description of the self-build Mullard 5-10 amp here:
http://www.r-type.org/articles/art-003e.htm Near the bottom where it provides the component list, it mentions some of the transformer brands and types that may have been used. I did wonder about that diference in measured resistance, but Ed has already provided the explanation. |
22nd Feb 2016, 12:07 am | #4 | |
Cheers WD. I might try and look up a few of those in addition to trying out the phasing test explained by ED. |
