26th Sep 2019, 11:51 pm | #1 |
Mains noise filter
Here is an unused filter purchased in Japan. It did not come with any instructions. Is this a mains filter that's supposed to remove mains-borne RF interference ? It has five terminals, two to the left and three to the right. If it is what I am thinking, how should it be connected to the mains ? Can someone please advise ?
27th Sep 2019, 12:16 am | #2 |
Re: Mains noise filter
Before wiring it up, do a meter test to confirm there is a circuit between pin 1 and pin 3.
Same between pin 2 and pin 4. Assuming that is OK (if not, tell us what you get): Pin 3 incoming mains active Pin 4 incoming mains neutral Earth to central pin Pin 1 active to circuit Pin 2 neutral to circuit You can actually change the incoming and outgoing around, I only suggested this configuration as it keeps the incoming earth line in proximity to the incoming mains active and neutral connections. |
27th Sep 2019, 1:15 am | #3 |
Thanks Terry. Pins 1 and 3 are continuous, so are pins 2 and 4. My meter momentarily read 50 to 60 Megaohms between pins 1 and 2 and the same between 3 and 4 before jumping to OL. The earth pin is not continuous with any other pin. If all is OK, I might connect this to the regulated variable PSU I'm building at present.
27th Sep 2019, 3:50 am | #4 |
Sounds OK, the momentary 50 to 60 Megaohms is the bypass capacitors charging, so that's OK.
Are you going to use it on the incoming AC feed or somewhere else in your power supply? |
27th Sep 2019, 6:36 am | #5 |
Also do you have any idea what the maximum current capacity is?
27th Sep 2019, 6:50 am | #6 |
1A, it's written on the front.
27th Sep 2019, 10:52 am | #7 |
Remember it'll only reduce conducted noise and then only if the earth at the point of use isn't as "dirty" as the line and neutral wires. A lot of mains borne interference actually gets picked up by radiation to the set in use, so the effect of the filter may be disappointing. Nothing to lose by trying it, though.
27th Sep 2019, 7:52 pm | #8 | |
The other issue is that the filter has pins that need to be soldered to a PCB and if I do that the PCB will have live mains voltage. Not sure how to insulate the PCB properly to make it acceptably safe and shock free. Any suggestions please ? |
27th Sep 2019, 8:05 pm | #9 |
Picture attached. The yellow wire is earth connected to the metal base of the enclosure.
27th Sep 2019, 10:05 pm | #10 |
I would just crimp a ring tag onto a short bit of green and yellow wire and add it to the earth post on the case and solder the other end to the filter earth.
27th Sep 2019, 10:39 pm | #11 |
If the filter has only pins and no other mounting arrangement then easiest way to use it would be to mount it on some 1.6mm ERBGF (fibreglass PCB material, bare- no copper) sheet with the pins pushed tightly through suitable holes. Soldered wire connections can then be made direct to the pins and the whole assembly mounted to the equipment using further holes in the ERBGF sheet and suitable nuts, bolts and spacers.
For the box you show, it could be mounted on its insulating plate on the outside of the box with suitable clearance holes in the box around each connection so that all wiring is inside the box.
28th Sep 2019, 1:36 am | #12 |
As per Herald, but I would mount the filter inside the box if you have the room.
If you make the standoff's fractionally shorter than the height of the filter, it will clamp it to the back of the case. |
29th Sep 2019, 1:24 am | #13 |
29th Sep 2019, 2:26 am | #14 |
And here is the filter mounted on thick insulating plastic material as I had no copperless board. The plastic in turn is screwed down to wooden blocks affixed to the base of the metal enclosure.
29th Sep 2019, 4:50 pm | #15 |
Other than the very slight extra fire hazard in the event of other problems from the use of wood and unknown plastic material (PCB ERBGF is usually rated for UL94-V-0 fire resistance) that should be just fine.
30th Sep 2019, 12:32 pm | #16 | |
Colin. |
30th Sep 2019, 2:45 pm | #17 |
Yes I agree you need a star washer between each layer of the termination.
