3rd May 2009, 8:26 pm | #21 | ||
Re: Mixer spurii - RSGB H/B 4th. Ed.
Dave, G8HQP, clearly explaines above that you choose the 'dot' results is you are selecting the sum for your mixing product, (F1 + F2), and the 'no dot' results if you are selecting the difference for your mixing product, (F1~F2). The 'dots' in the RSGB table are clearly not decimal points. HTH Al. |
3rd May 2009, 10:11 pm | #22 | |
Since the products of a non-linear so-called mixing process can be represented by a chain of signals whose frequencies are mF1 + or ~ nF2, where m and n are integers, why the restriction "F2 is close in freq. to F1"? Although the subject - in the broadest sense is 'complex' - there doesn't seem to be anything particularly complex about these two equations. If I've misunderstood you, please accept my apologies; perhaps you'd care to expand on your thinking here? Al. / Skywave. |
3rd May 2009, 10:27 pm | #23 | |
3rd May 2009, 11:11 pm | #24 |
Hi Dave/Al,
You are correct I did not see the RSGB scans posted earlier. Mike |
3rd May 2009, 11:23 pm | #25 | ||
Mike |
3rd May 2009, 11:33 pm | #26 | ||
Two things are established by the above: (a 1) when you do write technical documentation, (even if you know that you are only the one who is ever going to read it), read it several times through and ask yourself "does this make sense?" Then repeat this a few days later; (a 2) assuming the necessary technical understanding, could I plonk this in front of somebody and feel confident that he / she could go through it without having to come to me and ask 'what does this bit mean?' ?" (b) the merits of a technical education, be this formal or self-taught. That aside, I (& Dave,G8HQP) referred earlier to a Spreadsheet version of the concept behind this graph / table combination. Not wising to forestall G8HQP's efforts on this, here's mine. It's an 'engineer's approach'; not particularly elegant, but - as far as I can tell - it works. If you find otherwise - please let me know. Al./ Skywave. Last edited by Skywave; 3rd May 2009 at 11:49 pm. Reason: Typo |
4th May 2009, 12:26 pm | #27 |
I too learnt, the hard way, that something I write now has to be understandable by me in six months time when I have forgotten the context. When I used to write software I tried to get people not just to document what they had done, but also why they had done it that way, and what other apparently superior ways they had rejected and why. This was because I found we were often sitting in technical meetings scratching our heads and wondering "Why did we do it that way when we wrote that last year?"
My Firefox opened the zip file and found nothing in it. I was going to attach my spreadsheet but I don't seem to have a copy of Zip on this machine - I need another round tuit! |
4th May 2009, 6:22 pm | #28 |
Well I guess Firefox wouldn't know what to do with a .xls file anyway....
Yes, I like your spreadsheet and a short play with it gives one a good understanding about what the issue is about. Much easier than trying to understand that chart of course. Now just need a mixer application to put it to use... One suggestion, the selection of f1+f2 or f1-f2 could do to being made a little easier. Since we need either one or the other then putting anything in the first box should automatically clear the second - or maybe some other means of setting this parameter. (and I can never understand people who don't have WinZip or equivalent on their computter, it is probably the most used program I have on mine and couldn't live without it.). Dave |
4th May 2009, 7:15 pm | #29 |
Here is my version of the spreadsheet - in three flavours: Works, Excel and OpenOffice.
4th May 2009, 10:12 pm | #30 | |
"An application to put it to use . . . ?" Ah-Ha! You've seen through my cover to where it all began! This all started when I got to the number-crunching bit of an AmRad HF bands ssb transmitter I am trying to design & build. Don't hold your breath though - it's a decidedly long-term, back-burner project. Re the 'input validation'; choosing one F1 + / ~ F2 option that inhibits the other choice. I did tinker around with a few ideas, but couldn't find a way within Excel of achieving that result. (I'm open to suggestions.) Anyway, my 'get out' on this is that I did say that this was an "engineer's approach" (read: to be used intelligently) Al. / Skywave. Last edited by Skywave; 4th May 2009 at 10:17 pm. Reason: Spelling! |
12th Jun 2009, 2:18 pm | #31 |
I have just obtained a copy of the Collins SSB book (2nd ed, 1959). I know it is on the internet for free, but I'm old enough to prefer reading from paper. Lots of useful information, although the earlier sections are clearly intended to convince their customers that they should move from AM to SSB (using Collins equipment of course!).
