Old 16th Jan 2026, 7:37 pm   #81
deliverance
Default Re: Selenium rectifier aeg
Your both wright a decent schematic would of helped still waiting for a manual that was posted on the 5th now to trace that wire I'm sure there we be a component frazzled somewhere.
deliverance is offline   Reply With Quote
Old 16th Jan 2026, 8:19 pm   #82
deliverance
The wire goes to 7 on the rear of the set used for break in I presume for a transmitter of some sort it is connected with a plug pull the plug with the last wire reconnected all is good connected the plug hot choke etc .
Old 17th Jan 2026, 12:55 pm   #83
Chrispy57
Hi Chris - that was good news to wake up to this morning, your painstaking efforts have finally been rewarded. Hope you enjoy using the set, it's quite a looker.
Chris
Chrispy57 is offline   Reply With Quote
Old 17th Jan 2026, 1:08 pm   #84
deliverance
Hi Chris the wire from the jumper goes to a board then two wires go to 2 EF85 valves around the tuning condenser there is a short in there somewhere I have managed to lift the tuning condenser up a bit at the back also a rear cover so can get to components it's tight in there .
Old 18th Jan 2026, 5:37 pm   #85
deliverance
Hi all just a quick update after unsoldering most of the components around the two EF85 valve sockets and what a pain it was anyway there was one cap 500v 10nf which was a dead short so replaced it along with some resistors and few more caps soldered everything back and I am pleased to say the set works well it's been on for most of the afternoon without drama . It works well on ssb and pretty stable .
Old 18th Jan 2026, 5:56 pm   #86
Boulevardier
That's brilliant - you've got there in the end! Well done for your perseverance. I think you were held up hugely by that wretched,broken-up schematic, which I found was almost impossible to follow.
Mike
Boulevardier is online now   Reply With Quote
Old 18th Jan 2026, 6:23 pm   #87
deliverance
Thanks Mike the schematic is a drama on its own .
Old 22nd Jan 2026, 10:16 am   #88
Originally Posted by Sean Williams View Post
Might be worth one of the Mods dropping the receiver repair based posts back into the original thread?
Threads merged.
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
