17th Jan 2021, 6:10 pm | #1 |
1.4V battery valves: how low can I go?
I've got a little single-valve regenerative shortwave receiver here - DF33 pentode, home-wound tuned-circuit, transformer-coupled to a WWII-surplus DLR5 headset. It's surprisingly effective at receiving 3.5 and 7MHz SSB.
Recently I noticed it was getting a bit twitchy to set the regeneration in the sweet-spot for resolving SSB; investigation revealed that the D-cell providing the LT was only delivering 0.7V off-load, which fell to 0.5V when it tried to power the DF33's filament. I'm impressed that my little Rx still worked under such circumstances - but it led me to ponder just how-low you can go with directly-heated-filament supplies. |
17th Jan 2021, 6:19 pm | #2 |
Re: 1.4V battery valves: how low can I go?
I think that would depend vary greatly on the condition of the valve, and perhaps, who made it. I recall the TRF I built using DF91's, as the batteries aged, it became pretty hard to see the filaments glow, even when they were still pulling in signals.
B
17th Jan 2021, 7:12 pm | #3 |
Yes in my experience the Dx91/96-series valves never really showed any visible filament-glow. My who-knows-what-it-had-been-subjected-to-before-I-got-it DF33 has the classic Mullard red spray-coating so I can't see the filament.
If it were in an application [such as a RF- or audio power-amplifier] where the cathode needed to emit tens of milliamps I'd be worried about running in what could be considered a cathode-emission-limited mode - but this little one-valver's HT consumption is only around a milliamp. And if it does prove long-term-harmful, well, I've got a couple of spare unused Mullard DF33 in the attic, which will probably still be there when they cart me off to the cremmie. |
17th Jan 2021, 8:55 pm | #4 |
I think 0.9V was normally considered the minimum heater voltage for 1.4V valves. Obviously being directly heated the cathode will still produce some emission at quite low voltages.
