Old 3rd Jan 2006, 11:12 pm   #1
high_vacuum_house
high_vacuum_house's Avatar
Smile Pye VT4 missing veneer on cabinet problem
Hello there,
I bought this Pye VT4 recently at the Radiophile auction and it has a good cabinet except for the top edge where some veneer has come adrift and gone missing (see picture) What is the best methood to repair this damage without having to strip off all of the veneer on the top surface and re-veneer it?
Many thanks,
Christopher Capener
p.s The welsh dragon is not being shown on the telly but the front implosion screen reflects very well even though it was designed to minimise reflections
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
Old 4th Jan 2006, 1:38 am   #2
Darren-UK
Default Re: Pye VT4 missing veneer on cabinet problem
If you're looking at a proper restoration and can afford it, these people do a pretty good job........ http://www.otterantiques.co.uk/Box-Restoration.htm
Otherwise, if you're wishing to do it yourself and have no proper skills in this field you've a major problem to effect an invisible repair. Shame the broken piece of veneer is missing; to find another piece that's an identical match and then to blend it in would be a patience-stretching job.
Darren-UK is offline
Old 4th Jan 2006, 9:06 am   #3
Duke_Nukem
Duke_Nukem's Avatar
Getting a good match using some repair pieces is going to be very difficult.
I suspect it'd be easier to remove the entire veneer from the top and replace with a complete new piece. A little mismatch between the new and old would be hardly noticable since the old and new pieces would be at completely different angles so pick up light differently anyway.
TTFN,
Jon
Duke_Nukem is offline
Old 4th Jan 2006, 10:08 am   #4
Sean Williams
Sean Williams's Avatar
Er, Might be worth a word with Tim (from Bradford on Avon) - another forum member.
I had a few old sets from him, and there was a VT4 cabinet in the same place - it might still be available, and from memory it wasnt in bad condition.......
Sean
Sean Williams is offline
Old 4th Jan 2006, 10:44 am   #5
Aerodyne
Aerodyne's Avatar
If you really want to do it yourself:
Strip the entire cabinet of its finish. Obtain some iron-on veneer (check internet for suppliers) of a similar colour and grain. Cut a thin strip using a new craft knife blade, along a dead straight edge. Remove the ragged edge of veneer on the cabinet down to a straight edge. Check for butt-fit of the new strip against the edges. Allow an overhang on the cabinet side of a few millimetres, for cleaning off. Iron the veneer into place. Cut or sand the overhang back to level with the side. Sand dead smooth, use a suitable colour of grain filler as required.* Obtain some toner spray* of an appropriate tone, for example Mahogany. Refinish the cabinet with numerous coats of toner, finishing with clear gloss spray.
The toner will gradually cover the grain and any variations in tone that exist between the new and the old, at the expense of the loss of the grain figure - but that isn't likely to be a problem with the already darkened tone of your set.
Don't overdo the toner in one area and do not sand excessively between coats - if at all - or you run the risk of cutting through the toner and exposing the lighter wood beneath, at which point you strip the whole thing again and start from scratch!
*Grain filler and toner spray products are available in the UK from
Restoration Materials
Barnside. 194 Wellington Road,
Bury
Lancs BL9 9AH
Tel 0161 7642741
No adequate web site, as far as I know, so 'phone first.
Needless to say, I have no connection with this firm in any way whatsoever...
-Tony
Aerodyne is offline
