Old 3rd May 2018, 10:07 pm   #1
CrackBangPop
Default Ferguson 356A. Resistor Identification
New to the site, first post!
First of all I'm new to all this, and don't have much electrical/radio knowledge but I'm fine with replacing a resitor or two.
I have a Ferguson 356a, not worth much and not a great radio I know, but I'd still like to get it running. Anyway it was tested and working upon receiving it, then set aside for a while.
I decided to give the a case clean so removed the back and immediately noticed a resistor with a broken lead, a 500ohm resistor, green, black, brown. But when I check the service sheet for the radio, there is no 500ohm resistor listed and wondered if the sheet is wrong or maybe somebody put in the wrong resistor and that's why it has a broken lead! Although it all looks original and untouched.
It runs from pin 9 of valve 2 (EBF80) according to the service sheet. I'm not 100% confident in myself following the circuit diagram so I'm wondering if anyone here could identify what it's actually meant to be.
image attached and can provide more if needed, I've read the rules and see I'm not allowed to post service sheets, I hope the cropped circiut diagram is ok.
Thanks in advance,
Marc.
ID:	162232   Click image for larger version
CrackBangPop is offline
Old 3rd May 2018, 10:36 pm   #2
Boater Sam
Default Re: Ferguson 356A.Resistor Identification
Reckon it's C28, a capacitor.
The rounded ends are the give away.
Boater Sam is online now
Old 3rd May 2018, 10:43 pm   #3
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Default Re: Ferguson 356A. Resistor Identification
Are you sure that isn't a capacitor? (C28 is connected between pin 9, which is earthed as you can see from the diagram, and the secondary of the I.F. Transformer. C28 is part of the filter circuit following the detector. The green, black, & brown bands would then indicate 500pf. This assumes you haven't actually measured the component at 500 ohms. (Boater Sam has just put it more succinctly!)
'LIVEWIRE?' is offline
Old 3rd May 2018, 10:43 pm   #4
Nuvistor
Nuvistor's Avatar
Yes I agree with you Sam, it appears to be C28.
Frank
Nuvistor is offline
Old 3rd May 2018, 10:54 pm   #5
dazzlevision
It’s a Dubilier capacitor. See photo 4 in post 1 here: https://www.vintage-radio.net/forum/...ad.php?t=98964
dazzlevision is offline
Old 3rd May 2018, 11:40 pm   #6
CrackBangPop
Oh wow, well that explains my confusion. I wasn't aware of such capacitors! I did think it was a little unusual how the ends are rounded but the stripes like a resistor threw me off.
I still have a lot to learn..
Thanks all for the replies!
Old 4th May 2018, 10:05 am   #7
HamishBoxer
HamishBoxer's Avatar
possibly .01 or 001uF cap.
HamishBoxer is online now
Old 4th May 2018, 10:34 am   #8
ms660
ms660's Avatar
Doesn't look like C28 to me, looks more like C23 (500pF) Check out pin 2 of the EBF80 to the IF transformer, pin 2 is g1, hence C23 on t'other end....The IF amp is a reflex job (IF/AF)
Lawrence.
ms660 is offline
Old 4th May 2018, 10:39 am   #9
Station X
Station X's Avatar
Agreed. It's connected to pin 9 which has a strap to the chassis and you can see a broken wire on what is presumably L6. The value is 500pF.
Graham. Forum Moderator
Station X is online now
Old 4th May 2018, 10:55 am   #10
dazzlevision
Agreed, C23. The green, black, brown colour code is for 500pF.
Old 4th May 2018, 11:53 am   #11
HamishBoxer
Of course Green = 5!
Old 4th May 2018, 8:05 pm   #12
CrackBangPop
Thanks again, so we're settling on C23 then. I did think it was goiNg to the 1st IF (L5/L6) before I posted since the broken lead is on what the service sheet says is 1st IF. So when it was first said that it may be C28 and going to second IF, I thought great, I know even less than I thought I did!
Also do I need any specific type of cap to replace this with? I'm mainly seeing poly or radial silver mica 500pf caps for sale, the silver mica seem easier to get hold off.
Old 5th May 2018, 9:15 am   #13
ms660
ms660's Avatar
Silvered mica will be ok to use.
The connections to the EBF80 can easily be confused when tracing out because there are three transformer windings connected to it, in this case g1 is IF in and AF in.
Lawrence.
ms660 is offline
Old 5th May 2018, 9:45 am   #14
dazzlevision
A close tolerance (usually 1%) Silvered Mica type may well prove expensive (if you have to buy one). A much cheaper axial leaded Polyester film 10% 250Vdc working type will be fine, as it is just a decoupling capacitor on the AGC line.
Old 5th May 2018, 12:33 pm   #15
G8UWM-MildMartin
470pF may be easier to find. Ceramic would also be OK.
G8UWM-MildMartin is offline
Old 5th May 2018, 3:11 pm   #16
CrackBangPop
Ah that's good to know thanks, so whatever I can find cheapest that's the cloest value.
I was also planning on changing the cap on the output transformer, it's a 0.002uf 1000v waxy paper cap but I can't seem to find any, all I can find at 1000v are 0.0022uf, would that be ok?
Also, could anyone recommend any books or links on the basics of how valve radios work? There's lots of information on the internet but I can't seem to find anything that just goes over all the basic parts, what they do, how and why etc.
Thanks again,
Marc.
Old 5th May 2018, 3:35 pm   #17
ms660
ms660's Avatar
0.0022uf is fine, no problem.
What does what.....have a look through this lot:
https://www.vintage-radio.com/repair...ion/index.html
Lawrence.
ms660 is offline
